Serpent 710
Originally Posted by InitialD
Damn. I should have known this and stocked up earlier. There goes our tires and fuel supply for 3 months.
Plastic Gears
While preparing my car for the upcoming state series I happened to notice that the 19t gear on the mid-shaft looks like an egg. The gear has rotated about 45 degrees on the hub. This is the 2nd time this has happened to me. Has anybody else had this happen or is it just me? Any suggestions on how to prevent this from happening again?
Thanks,
jag
Thanks,
jag
i have a brand new in the package 2-speed (even comes with both spur gears) for sale. at the store they are like 79.99. i will sell for $45.00 including shipping.
Thanks,
jag
Thanks,
jag
Before you just replace the pulley, have a look at the alu part. The flat spots can wear and make it easier for the pulley to slip.
A trick to prevent this is using a bit of silicone sealant or thick thread lock between the adapter and the pulley. That'll stop any play from develloping.
Thanks,
jag
Thanks,
jag
Originally Posted by Julius
Haven't seen that happening. I want your engine
The motor is Francis' old Rody and it flies!
Jim
Originally Posted by JustRace
Jag....must be the motor that I sold you I would change the aluminum if there's any sign of wear. You better go over that car real good because Niketa is coming on strong this year
Originally Posted by gfd2726
Hi guys,
I am having problem with my 2 speed transmission... For some reason, it won't shift... I tried loosen & tighten both screws but still not shifting. How many turns out do you guys recommend? I have a Sirio Evo III 3 ports in this car. Anybody has similar problem before with their 2 speed not shifting? I am not new to nitro but new to 710. Please help. Thank you.
I tend to agree what joemugen has mentioned. However, I have found that if the 2 speed aluminum bell wears out in the inner side, the gap between the white shoe and the aluminum bell widens and any which way you adjust the spring tension on the shoe would not make the 2nd gear shift. I find that if you do not sand the white shoe with sand paper to clean it (very bad idea), the white shoe seldom wear out. The aluminum bell wears out faster.
That's the time you know that you have to get a new one.
From what I can remember, when the aluminum bell reaches to 0.5mm thick, then it's time to change.
New Chassis
Hi guys,
I am using the new chassis and I have a problem with the height of the exhaust. It's now about the same height as the chassis and it hits the ground when there is chassis roll going round a sweeper.
Any of you encounter the same problem?
Any suggestions for remedies?
Cheers...
Cheers...
Originally Posted by Darth Vader
Hi guys,
Cheers...
Cheers...
Have you tried another spring? I have a spring with an option to mount the exhaust higher.. of does the exhaust hit the ground just after the exhaust-bend?
Cheers...
i have a mount with 2 holes in it.. so i can mount it higher...
OK, I'll check and try it this weekend.
Thanks...
Hi,
I just bought a Max Power 2615E pipe for my 710, unfortunately it uses a different manifold to a Max Power 2602 or many Novarossi's. The inlet from the manifold to the pipe is bigger.
Does anyone know of another brand manifold that will fit as the Max Power is out of stock in HK.
Thank you
Thank you
Thank you
Thank you
