Old 04-07-2005, 11:22 AM   #21001
jag
jag's Avatar
Originally posted by InitialD
Ok, I just got to installing the 20T pinion just now and this is what I found out...
Firstly, I mounted the 1st gear pinion with the 5x10x4 bearing. Then screwed the 1st gear pinion to the 20T 2nd gear pinion by hand as tight as I could.
Then I screwed the 1st and 2nd gear pinion assembly by screwing the 2nd gear pinion onto the lightened clutchbell. Used my 802514 Serpent Centax-3 Clutch Housing Tool to hold the lightened clutchbell and then used my 1st gear pinion holder to tightened the pinion assembly onto the lightened clutchbell.
When you do this, the 2nd geat 20T pinion automatically gets tightened as well.
That's using your noodle. See, all it takes is a Jedi Master to figure it out.
jag is offline   Reply With Quote
Old 04-07-2005, 11:25 AM   #21002
E2
Hello all,
i just picked up an impulse pro second hand. I know that there are no shops local in Cincinnati, OH that carry parts. What is a good online retail shop for serpent parts?
Thanks,
Eric
E2 is offline   Reply With Quote
Old 04-07-2005, 03:26 PM   #21003
Sow&Steady's Avatar
Originally posted by JustRace
Oh...that's it. He's missing his reading glasses.
Yeah, thanks to MarkP27!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-07-2005, 03:27 PM   #21004
Sow&Steady's Avatar
Sow...why is that? I've used this tool with the lightweight bell with no problem.
I can't get the pin to line up properly with the slots in the lightened housing.
Old 04-07-2005, 03:41 PM   #21005
JustRace's Avatar
Master D....did you notice that when you install the bearing into 1st gear pinion that the bearing won't stick coming out?
I hope Sow caught the part "Centax-3 Clutch Housing Tool to hold the lightened clutchbell".
Sow maybe the holes on your clutch bell might be off? Or is it time to move up to the next magnification
JustRace is offline   Reply With Quote
Old 04-07-2005, 04:09 PM   #21006
Originally posted by E2
Hello all,
Thanks,
Eric
E2
If you are not able to find any shop that carries the parts you need, you can call us directly and we will be more than happy to service you
Paolo Morganti
Serpent USA
305 6399665
Paolo M is offline   Reply With Quote
Old 04-07-2005, 08:21 PM   #21007
InitialD's Avatar
When I got my tool, I noticed that it was really tight fitting to make it seat deeply into the clutcbell. Ended up the tool having scars and scratches at the side as there were burrs in the inner part of the clutchbell. That could be your problem.
Well, the tool now is made of aluminum. Not like the other Centax 1 and 2 tools that were made of Hudy spring steel.
Old 04-07-2005, 08:28 PM   #21008
InitialD's Avatar
I noticed that this time the bearing seems looser in the 1st gear pinion before I screw on the 2nd gear pinion. And after screwing the 2nd gear pinion, it is still loose...
Electron microscope.
Old 04-07-2005, 10:57 PM   #21009
markp27's Avatar
Send a message via ICQ to markp27
Well I never!!! The cheek of it
markp27 is offline   Reply With Quote
Old 04-07-2005, 11:03 PM   #21010
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Hello Mark ,do you know what the stroke is in this engine (MEG2103RMS NovaMega SX12 RE 3P Race MS ) ?
if you know or anybody else knows ,thanks in advance!
Old 04-07-2005, 11:15 PM   #21011
markp27's Avatar
Hi Marcos!
Here's the info you are looking for
http://www.mytsn.com/products/specs.asp?prid=681
Old 04-07-2005, 11:25 PM   #21012
Super Moderator
Marcos.J's Avatar
Hi Marcos!
thanks very much!!!!!
Old 04-07-2005, 11:27 PM   #21013
markp27's Avatar
no problemo, matey!
Hey have you changed to a Schumacher car now??
Old 04-07-2005, 11:27 PM   #21014
Darth Vader's Avatar
Originally posted by lagnaf
Look guys what happend to my friends engine after a good 1 hour of racing on Serpent Challenge in Kirchberg Austria.
He used only one plug so the plug couldn't do that.
What do you think happend here ?
Here is the link to the pictures.
I think his air filter fell off or not working well.
My old pull start engine looked exactly like that when I ran it without the air filter.
Darth Vader is offline   Reply With Quote
Old 04-07-2005, 11:30 PM   #21015
Trust the Prophet to come up with the solution...
