Old 01-30-2005, 11:35 PM   #19846
thamjk's Avatar
Default Re: Re: Re: Re: Re: Solid Front Axle set up
Originally posted by InitialD
No. He took the front ball diff axles and pulley and physically locked it. So there's no more diff action on his front "ball diff" anymore. Don't know the details but Uncle Crash thought he heard him say that he locked the front ball diff with a glue. I actually did not take a close pic of it but he took off the diff collar too as it was not required.
From my experience, what I did was replacing all the dif bearing to a custom made cylinder cube where the dimension was fitting nicely. Tighten the center allen screw and you will have no way for diff action, completly solid. That was before my solid axle come out.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 01-30-2005, 11:45 PM   #19847
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Solid Front Axle set up
If I'm not wrong, you're relying from the metal to metal friction these cylinder metal pieces will provice against the metal plates? So how many of these cylinder metal pieces did you put to replace the balls? They should be 4 x 4 mm measurement right?
Old 01-30-2005, 11:59 PM   #19848
thamjk's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
Correct, just replace all the bearings. The only concern here is where to get those cylinder metal pieces? My rear diff outdrive cup start to wear out, any solution?
Serpent 710
Nova MAX
3PK
Old 01-31-2005, 12:31 AM   #19849
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
I guess get a 4 mm cyclindrical rod and cut them out at every 4 mm intervals...
Replace one side of the dogbone with a 11.7 mm pin. The stock one is 9.7 mm. The side of the dogbone with the longer pin should go into the diff outdrive.
Of course, replace the diff outdrives with a new one and with these modified dogbones, the diff outdrive will last much longer.
Old 01-31-2005, 01:00 AM   #19850
thamjk's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
That is one way another of doing it. What about the dogbone, where can we get those pins?
Serpent 710
Nova MAX
3PK
Old 01-31-2005, 01:08 AM   #19851
Sow&Steady's Avatar
Originally posted by markp27
Yeah and we all know which Mini you're thinking about.......skirt!!!
Geez Mark, I know you're old but I didn't realise you were already born during the mini-skirt era!
What's the difference between panties in the 60s and panties these days?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-31-2005, 01:17 AM   #19852
markp27's Avatar
Send a message via ICQ to markp27
I think I caught the tail end, as it were
I don't know if I should answer that question
markp27 is offline   Reply With Quote
Old 01-31-2005, 01:29 AM   #19853
Sow&Steady's Avatar
Anyway, I also changed the dogbone pins from time to time as they flatten out after constant usage. What I do to pro-long the usage of these pins is to knock them out, turn them 90 degrees and knock them back in. You'll get a "new" pin.
[/B]
Good tips D, not sure what Serpent thinks of these cheap mods but I'm sure they'll survive!
Any good tips for a cheap Shuffle? Maybe knock something out of a cassette player and then hammer parts of it back into a broken pen-drive case and voila! Cheap iPod!
Old 01-31-2005, 01:35 AM   #19854
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
Ummm, not mine though. I cannot take credit for this. It's from Per-Ola Hard. Remember him?
No comments ! I wanna wait for a free iPod. Don't go spoling my chance.
Old 01-31-2005, 01:38 AM   #19855
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
Is he still around? They're so quiet these days ... maybe that's why ... Serpent found out he was knocking out pins and replacing them and ... take a guess.
Man! That's even cheaper than cheap!
Old 01-31-2005, 01:40 AM   #19856
Sow&Steady's Avatar
ROFLOL ... caught the "tail end" ... VERY good one! That deserves 5 "lol" at least so here ...
[i] I don't know if I should answer that question [/B]
Errmm, agreed ... don't want to get you and me banned around here.
Old 01-31-2005, 01:40 AM   #19857
InitialD's Avatar
Usually, the hardware shops that deals with bolts and nuts will have them. They are called dowel pins. But they come in standard 12 mm or 10 mm. The ones we're looking for is 11.7 mm and 9.7 mm. So therefore you need to do some grinding off the edge of the pins to round and chamfer them.
Old 01-31-2005, 01:44 AM   #19858
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
I think he's under the frozen pod hibernating.
I always strive to be better.
Wait a minute... Who do you call cheap? A person who knocks out pins from a dogbone worth few bucks or a person who waits for a free iPod?
Old 01-31-2005, 01:47 AM   #19859
InitialD's Avatar
Digging out old discussions Onkel Sow?
Americans: Panties as in Pants as in Trousers.
British: Panties as in underwear !
This was what Mark confirmed too.
Old 01-31-2005, 01:50 AM   #19860
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Solid Front Axle set up
Well, being winter in Europe, one would froze anywhere anyway ... just ask our friend over there who is planning on running over to Floriday just to start his engine up!
That sounds a trick question ...
