Old 01-18-2005, 02:21 AM   #19501
Originally posted by InitialD
Don't worry ! The 2006 1/10th WC will be in Ozzy land ! What more can you ask for?
yes but i doubt i will be able to speak to the team and get tuning info from the best!
Brett.w is offline   Reply With Quote
Old 01-18-2005, 02:24 AM   #19502
InitialD's Avatar
Well, I think if you stick with Serpent, you should be able to do that just fine. All the factory drivers were willing to help or answer any question you have about the car.
My RRL5 engine got "mollested" by MS while Uncle Crash's 710 got "mollested" by him as well...
Old 01-18-2005, 02:37 AM   #19503
Stick with serpent, iam already stuck! apart from my "old" 710 arriving today
Old 01-18-2005, 02:45 AM   #19504
Pyramid's Avatar
not to worry lah.. when it got hit at the right spot, things will eventually broke and time for you to replace it anyway.
Pyramid is offline   Reply With Quote
Old 01-18-2005, 02:57 AM   #19505
kitracer's Avatar
Originally posted by Pyramid
ahh now I got it why he said he has a wrong ride height to start (5mm was it Lee?). The rev5 will let you coast with 6.25mm rear ride height @ 37s all around, I believe Fabio already examined Heri (Kris Heriana) car thouroughly.
I started at 5.5mm rear / 5 front and the car acted very funny for the first 10 mins. but got better and better. My best lap was before my last pitstop ( ) but what the heck.
Always next time.
kitracer is offline   Reply With Quote
Old 01-18-2005, 03:04 AM   #19506
InitialD's Avatar
Always next time.
I think we should all post and compare our setups here just to see what was done and to see how much difference from one car to another... Will get back and check the setup and post it here probably tonight.
On another note, I'll send you an email in a while...
Old 01-18-2005, 03:56 AM   #19507
Regional Moderator
daniz24's Avatar
Is it just me, or the front body hole is way oversized???
daniz24 is offline   Reply With Quote
Old 01-18-2005, 03:58 AM   #19508
Regional Moderator
daniz24's Avatar
And the rear side windows too... New rules??
Old 01-18-2005, 06:12 AM   #19509
InitialD's Avatar
Which one are you referring to? The bodyshells on the lineup?
Yeah, they were huge. But as far as we're concern, we follow the rules. Even to the trackwidth and rear wing height.
I hear that some even run as wide as 205 mm in order to get rid of traction roll and have humungous rear wings ! Talk about outlaw...
Old 01-18-2005, 06:18 AM   #19510
Sow&Steady's Avatar
Anyone here have info on races (1/10 GP) that will be held either end of this month or first week of febuary near Crewe, Cheshire, UK? or to the nearest city that has an International Airport. Thanks
*Ahem*, Pyramid, my home track is only 40 minutes from Heathrow.
We're also a visiting-racer-friendly.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-18-2005, 06:20 AM   #19511
Sow&Steady's Avatar
Default Re: Prophet hard at work
Originally posted by crashed_1
Prophet hard at work ...
Crashed, looks like he's really happy actually ... I suppose when you smoked everyone, you deserve a snigger or two.
Old 01-18-2005, 06:22 AM   #19512
Sow&Steady's Avatar
As far as I know, everybody had traction roll problem. Even in the B main, kitracer traction rolled twice. I was on solid and was having a little bit of traction rolling problems earlier. Not as much as Uncle Crash though... But Uncle Crash sought the EMPEROR's help and managed to get rid of his traction rolling problems !
I went with harder front tires. But later on I found out that it could be the tire diameter that I was using was not correct and probably made for the slower corner entry / exit. Changed it back to 37 front and rear with 59 mm rear and 58 mm front tires during the main and it was on rails.
What do you mean by "not correct"? What were you using before changing over?
Old 01-18-2005, 06:23 AM   #19513
Sow&Steady's Avatar
Thanks Bro.. the problem is, I did not even know where Chesire is (I just know whom I need to meet), so I wont know the nearest city either that`s just a plan, not fixed yet.
Oh I see ... OK, go over and look at AMCCs only in the calendar. you're most likely flying into Heathrow, AMCC is only 40 mins south of that airport and then when you've had fun you can go over the Chesire.
Old 01-18-2005, 06:41 AM   #19514
InitialD's Avatar
It's weird actually... Available traction kind fluctuate in the duration of the whole weekend. When traction was high during practice before the rain, I thought 37 front and rear was a little twitchy for me to drive. So I had 40 fronts and 37 rears which drove OK and even had 42 front and 40 rears at some point.
In the end, it was a gamble as I took the risk of using 37 all around without having to test what tires were good for that Sunday morning. I told my venerable wingman <cough, cough> to prepare for front tire change to 40 front in that 3 minute given warm up time in the event the 37 fronts did not work out. But all came out well and good.
Old 01-18-2005, 06:42 AM   #19515
InitialD's Avatar
Default Re: Re: Prophet hard at work
How could I have been happy and sniggering? It was 1st day at the track lah...
