Old 11-30-2004, 09:44 PM   #18871
Originally posted by redsand
Didn't mean to step into GoldFinger's shoes .
Dont ! It hurts you know..
GoldFinger is offline   Reply With Quote
Old 11-30-2004, 10:13 PM   #18872
InitialD's Avatar
Originally posted by Pyramid
This time I have to ask, did you cut and paste his name or you can remmber how to spell
It's the RING.
Old 11-30-2004, 10:26 PM   #18873
InitialD's Avatar
Originally posted by JustRace
While holding the two outdrives the pulley should not turn at all. Correct? Now how much force do you use to try to turn the pulley?
Yes, the diff pulley should not slip. Tighten the screw just enough so that the diff pulley stops slipping. After that is done, then the last step would be to tighten the grub screw which should lock the position so that the setting does not run and cause the diff to slip.
For more detailed information, you can have a look at Julius' article on how to build the 710 diff correctly.
If the pulley does turn that means the diff is too loose. If you try to drive the car in this condition will the car pull to the right under acceleration and go left under braking?
That is right. I know that it will pull to the right under acceleration because when the diff is set loose, the diff collar holds the left side of the rear diff and letting the right side slip. Hence that's why you get that anomaly. I believe that explanation is the same during braking... The right side slips during braking and that's why the car goes to the left side.
So that is why sometimes you find people saying that you should not use the diff collar because the car swerves to the right or left but in fact it is the diff that is set incorrect.
Old 12-01-2004, 12:46 AM   #18874
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
(Rev5) is coming...the spoiler!
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 12-01-2004, 12:48 AM   #18875
Pyramid's Avatar
Originally posted by InitialD
It's the RING.
Not to try questioning the RING, in case you got time, tell us what`s the different in this picture,
http://www.daltonshop.com/images/rev5temp1.JPG
Pyramid is offline   Reply With Quote
Old 12-01-2004, 12:49 AM   #18876
Pyramid's Avatar
My God... you beat me to it
Old 12-01-2004, 12:55 AM   #18877
jfc_tech's Avatar
My God... i have no intention to do that...but i do feel proud i managed (j/k)
Old 12-01-2004, 01:00 AM   #18878
Pyramid's Avatar
but you already have the other pic which is supposed to give better hint if you couldn`t see it on the pic from link above
Old 12-01-2004, 01:03 AM   #18879
Sow&Steady's Avatar
Woo ... slow down here. I must admit, I missed the update for Rev 3 ... was that the monoblock and the tank?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 12-01-2004, 01:07 AM   #18880
InitialD's Avatar
You must have the RING then...
Old 12-01-2004, 01:10 AM   #18881
InitialD's Avatar
I give up.
Old 12-01-2004, 01:17 AM   #18882
jfc_tech's Avatar
is it no wonder, i've been disturbed by this weird dream of me keep watching the TLOTR movies...over & over again
seriously...even i got the picture, but still no idea whether its been mod already or not
Old 12-01-2004, 02:13 AM   #18883
Pyramid's Avatar
But if you post the second one, I bet the Prophet will know what it is
Old 12-01-2004, 02:15 AM   #18884
Pyramid's Avatar
to be honest, I also forgot will try to give some cut off line next time.
Old 12-01-2004, 06:32 AM   #18885
jag
jag's Avatar
Bro, using good grease like the Mugen Super Grease, I still have grittyless rear diff after nearly one year of running ! Same balls with the same diff plates. This also I rarely take it apart to service. If I remember only 4 times. The tracks we play here can sometimes be very dusty too and it has not affected the rear diff too much.
Put some Mugen Super Grease on a paper tower and rub the 4 mm balls with it so that the grease is lighly coated on the balls. That's the only trick and one of the best tricks yet for this car.
Do you put grease an the ceramic balls as well? Mine is super smooth without grease.
jag is offline   Reply With Quote
