Serpent 710
Originally posted by markp27
Ok, question about the bodyshell. How high/low do you trim the body shell? i.e. what is the gap between the bottom of the body shell and the track after the supension has been compressed?
The IFMAR rules mention the following about the height of the bodyshell;
Height (to top of roof measured with a 10.00mm spacer under the chassis plate on levels)
Min - 120.00 mm
Max - 175.00 mm
With those measurements, my Mazda 6 bottom shell scrapes the track very slightly when I apply brakes with 57 mm tires.
To mount the Mazda body, flip the rear posts over to the other side of the shock tower.
Th body should be trimmed level with the bottom of the chassis or slightly higher(1mm). You want it as low as possible to limit the amount of air going under the car which creates lift and doesn't let the body do it's job, to produce downforce. If the body is trimmed level with the chassis and it is scraping during cornering, the ride height is too low and the chassis is bottoming out which is a setup issue not a body issue.
Re: Re: Re: Gear Diff
Originally posted by InitialD
Seriously Pyramid? What maintenance? I have not taken my ball diff apart for very long time already. Still very smooth and grittyless.
Here is come the problem from where we stand in our part of the world. This toys cost a lot (our average nationwide household income consider at 1/4 to the US), no doubt some people like to somehow `rewarded` from those (a lot) xtra money they spent. How? mostly by winning the races (yes, A main) but that is not the case in this hobby. It`s not like paying someone to install state of the art car audio so you could win the IASCA of such thing. This point of view combined with regular or just for fun racers, we are forced to comes up with better system (according to our particular situation) to penetrate our local Serpent market better. Why better system? well, better human (the fingers) is the hardest part to do, better system is easier in which we came up with those Rev5 in mind (this gear diff idea is not the main subject of Rev5 ). So what we are hoping is they could enjoy the car more by driving it more in order to maximize their spending. 1st is to have fun, 2nd to win the races, 3rd our local serpent support = better market penetration (we certanly do hope so, Goldfingers especially )
In case anyone have more info on which brand of car gear diff that is clostest match to S710 rear bulkhead space and rear belt placement, please share some lights
Re: protoform bodies
Originally posted by Brett.w
I have just recently bought a nemisis and mazda 6 body but they dont seem to fit, the rear wing mounts are directly on top of the rear posts. How have you guy got around this issue?
joining to shock towers and placing the rear body post "inside" on the shock towers will let you get by the wing mounts of the Protoform bodies. Also try to get the body as close to the front bumber........this will also help in preventing from crack front fender wells on impacts.
Originally posted by XER987
Thanks...I'll probably be checking back for other tips...all help is very appreciated.
Which one?
Which one?
Errmmm ... maybe not 'cos I think it says WC somewhere on that engine.
Re: Re: Re: Re: Gear Diff
Originally posted by Pyramid
Hi Lord, the idea is simple ...
Re: Re: Re: Re: Re: Gear Diff
Originally posted by Sow&Steady
He needs stuff he can prophesize to do that!
Re: Re: protoform bodies
Originally posted by PUNISHER
Yes,
Yes,
True that putting the body closest to the front bumper prevents cracks but I believe Julius mentioned that the body position should be experimented. About 2 to 4 mm (I believe) to get a better balance in handling. More steering perhaps. In those cases, I think some kind of padding could be mounted on the underside of the bodyshell front.
Aluminum Pulleys
Ronald Baar mentioned on mytsn that the Serpent aluminum pulleys will be available in 2005 and that there will be a 21T pulley supposedly for overdrive.
Re: Aluminum Pulleys
Pyramid, may I remind you that he is no longer a lord
Suspended
Re: Re: Aluminum Pulleys
Originally posted by SERPENTFREAK69
SERPENT USA JUST GOT THEM IN TODAY...CHOCO
Suspended
Re: Re: Re: Aluminum Pulleys
Are you sure they are 710 ones? Or did you mistake the 3Racing aluminum pulleys?
