Serpent 710
Old 10-20-2004 | 10:16 AM
  #17926
pelos's Avatar
Default Re: Re: Servo Saver
Originally posted by Julius
You will need to make the steering link between the servo and servosaver a little longer, and reset your end-point settings on the transmitter.
Mine is actually set at 39.5mm with a Sanwa VRX.
Should I set longer too? How much?
pelos is offline
Old 10-20-2004 | 10:20 AM
  #17927
jag's Avatar
jag
The end-points is fine but could you define "a little longer" for the link? If it matters, I am using a Hitec 5945 servo.
jag is offline
Old 10-20-2004 | 11:12 AM
  #17928
Julius's Avatar
Default Re: Re: Re: Servo Saver
I wouldn't know how much longer. But we changed the angle between the two parts of the servo saver. Before at maximum left throw the saver and the link to the servo would be almost in a straight line which was not ideal.
You want to get the saver in the center position with the servo arm leaning slightly forward.
If you get equal throw in both directions with close left/right end point settings on your transmitter you're ok.
Julius is offline
Old 10-20-2004 | 11:33 AM
  #17929
jag's Avatar
jag
Default Re: Re: Re: Re: Servo Saver
So the angle of the mounts has changed a little bit. I will keep that in mind when I install it. Should the lever hit either of the front bulkheads? It looks very close right now. Need I be concerned about the clearance at the front pully?
It's great having you here for assistance.
Thanks alot.
Jim
jag is offline
Old 10-20-2004 | 11:46 AM
  #17930
markp27's Avatar
Unhappy Where has The Border shop gone?
Just wanted to go to the Border shop and it's not there!!!
Trying both www.the-border.com and www.the-border.nl land me at a Computer parts retailer (Dijkstra Online Shop)
Have they been hacked?
Mark.
markp27 is offline
Old 10-20-2004 | 11:51 AM
  #17931
Default Re: Where has The Border shop gone?
Mark.
Hi,
Try this:
http://shop.the-border.nl/customer/home.php
That way you fool the hackers
Thomas
840918001 is offline
Old 10-20-2004 | 12:19 PM
  #17932
markp27's Avatar
Default Re: Re: Where has The Border shop gone?
Originally posted by 840918001
Hi,
Try this:
Thomas
Thanks, but still rather strange
markp27 is offline
Old 10-20-2004 | 02:05 PM
  #17933
Julius's Avatar
Default Re: Re: Re: Re: Re: Servo Saver
Thanks alot.
Jim
It should be clear of all.
Julius is offline
Old 10-20-2004 | 06:52 PM
  #17934
InitialD's Avatar
Originally posted by Sow&Steady
Because he can't have an Apple, he Thinks Different?
Those who think different are the ones that makes the difference.
InitialD is offline
  #17935
InitialD's Avatar
Julius, you're referring to the 44.5 mm linkage in the manual?
InitialD is offline
Old 10-20-2004 | 06:57 PM
  #17936
InitialD's Avatar
Jim, are you using oneway front or a the front ball diff?
If you're using the front ball diff, then you need to change to the new 2 piece diff clamp that comes packaged together with the new servo saver (802145) for better clearance. Or you can get that part separately (802387).
InitialD is offline
Old 10-20-2004 | 07:02 PM
  #17937
InitialD's Avatar
Originally posted by rcpanama
I do have the 2.5mm install is 2.5mm inside the ball (stiffer)
You mean you mount the rear sway bar link on the inside of the rear lower arm (the manual suggest the outer part)?
Mounting it inside gives a softer setting.
I have the new MID position that will change from LT to mid position before LB, I might use this change to see.
Ah... You have the new option part (802325)? I got that some time already but never thought of installing it.
InitialD is offline
Old 10-20-2004 | 09:40 PM
  #17938
markp27's Avatar
Thanks, D
markp27 is offline
Old 10-20-2004 | 10:12 PM
  #17939
InitialD's Avatar
Thanks, D
That does not include those with different operating systems !
InitialD is offline
Old 10-20-2004 | 10:34 PM
  #17940
markp27's Avatar
Says so in the advert!
markp27 is offline
