Old 10-20-2004, 05:52 AM   #17911
rcpanama's Avatar
Thanks D for your response
Originally posted by InitialD
Try and use the new harder 2.5 mm sway bar. It should work good with oneway or front ball diff. You may want to adjust the front sway bar to harder to take out steering and balance the car.
I do have the 2.5mm install is 2.5mm inside the ball (stiffer)
[i] If the rear swings out a little, try UTI / LB. If you want the car to react faster left to right, use NO shims under the front upper arms..[/B]
I have the new MID position that will change from LT to mid position before LB, I might use this change to see.
[i] To get more on power steering, you may want to try less rear toe in like +1.5 or even +1.[/B]
I do need more on power steering
[i]And yes, don't forget to try the new servo saver if you have it. Good for high speed sweepers. [/B]
I am already using the new servo saver and it works beautiful. I have Shorten the lower from arm to 1mm but have not installed it jet.
rcpanama is offline   Reply With Quote
Old 10-20-2004, 07:38 AM   #17912
Sow&Steady's Avatar
Default Re: Re: [size=4]New build for 710[/size]
Well, one thing about that old "Tech Elite" you're referring to did not get the latest 710 kit. Our friend the ever hip Uncle Crash (another Tech Elite) did up one last week with a new batch of the 710 and check out what he found in the kit;
1. Rear shocktower with old design (gives you opportunity to throw it back to Serpent )
2. New Diff clamp for rear diff
3. Additional 1.2mm shock pistons on top of stock 1.0 mm ones
4. Additional 0.5mm spacers for front roll center
5. Old lower rear arms...
6. Reinforced upper and lower bumper brace
7. Black anodised flywheel
BTW, u sure about the 0.5mm spacers for the fr roll ctr? Too thin no?
I have that black anodised flywheel and I really like it ... smooth engagements and when you service all you need to do is wipe it with your thumbs and its back to a polish finish!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-20-2004, 07:39 AM   #17913
Sow&Steady's Avatar
Default Re: Re: Re: [size=4]New build for 710[/size]
Originally posted by crashed_1
Ummm...correction to item no. 4. It's actually Imm spacers plus the original 2mm ones.
Heh ... I tot so.
Old 10-20-2004, 07:40 AM   #17914
Sow&Steady's Avatar
Originally posted by markp27
Hey Crashed, great video - more please
Hmmm and what was the Prophet's car doing mixing it with the Lolitas?
Because he can't have an Apple, he Thinks Different?
Old 10-20-2004, 07:42 AM   #17915
Sow&Steady's Avatar
Default Re: Winternats Markp27
Originally posted by 840918001
Hi Mark,
I have read that you're going to race the winternats.
That's great man, the best way to improve your skills is due to drive against all the topguns.
Go there with a new Mega, maybe the team can tune it for you
Good luck there, and enjoy yourself!
Bye Thomas
What about yourself? Are you going to be there?
Old 10-20-2004, 08:06 AM   #17916
Default Re: Re: Winternats Markp27
Hi,
No, I'll be running the indoor elecric nationals then here in the Netherlands.
Bye Thomas
840918001 is offline   Reply With Quote
Old 10-20-2004, 08:14 AM   #17917
Sow&Steady's Avatar
Default Re: Re: Re: Winternats Markp27
Hi,
Bye Thomas
Ah, forget the EP, go nitro man!
Old 10-20-2004, 08:21 AM   #17918
Default Re: Re: Re: Re: Winternats Markp27
Hi,
I race Nitro all season long and in the winter I race EP, and a few indoor Nitro races.
I will give Salven a change, by not coming to that race
Bye Thomas
Old 10-20-2004, 08:36 AM   #17919
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Winternats Markp27
Hi,
Bye Thomas
Ah right. Ah well, maybe you'll come to the Euros in 05 then ...
Old 10-20-2004, 08:40 AM   #17920
Default Re: Re: Re: Re: Re: Re: Winternats Markp27
Hi,
I'll be at the 2005 Euro's.
My teammate was 2nd at the Dutch nationals so he will race there and I'll be therer with him.
Bye Thomas
Old 10-20-2004, 08:59 AM   #17921
Suspended
i cannot wait to go...choco
SERPENTFREAK69 is offline   Reply With Quote
Old 10-20-2004, 09:18 AM   #17922
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Winternats Markp27
Hi,
Bye Thomas
I'll be there too but just to watch. The UK was only allowed 25 drivers and there's over 100 in the queue!
Old 10-20-2004, 09:19 AM   #17923
Sow&Steady's Avatar
Me too ... only problem is the work sched is not finalise and right now there are clashes.
Old 10-20-2004, 10:01 AM   #17924
jag
jag's Avatar
Default Servo Saver
I am going to install the new (longer) servo saver lever this weekend and just wanted to know if there were any special modifications I will need to make or do I just install it like the original?
jag is offline   Reply With Quote
Old 10-20-2004, 10:31 AM   #17925
Julius's Avatar
Default Re: Servo Saver
You will need to make the steering link between the servo and servosaver a little longer, and reset your end-point settings on the transmitter.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
