Old 10-18-2004, 08:11 PM   #17851
rwisejr's Avatar
Send a message via AIM to rwisejr
Thumbs up Re: Re: Re: Re: hey
Originally posted by Marcos.J
it worked out pretty good , im going to try it out this weekend on a larger track!
rwisejr is offline   Reply With Quote
Old 10-18-2004, 08:13 PM   #17852
rwisejr's Avatar
Great glad to hear .I hope to paint mine this week and get a test run this weekend.I have been to busy and I don't like missing my recreation activities.
Old 10-18-2004, 08:53 PM   #17853
sparksy's Avatar
Trader Rating: 14 (94%+)
Originally posted by InitialD
How's the new Ellegi tires?
They look the goods... but I dont like how wide they make the car. I realy had to wrench on the balls to bring the track back under 200mm, and it caused the dogbones to bottom out in the outdrives and axle before the suspension reached full travel. The hex in the rim is also very tight when first put on the car. The actual rubber felt like it had no advantage from other tires
I will only use the couple of pairs I have. Then back to Speedmind. The ellegi is more expensive, and not worth the hassle in my opinion.
sparksy is offline   Reply With Quote
Old 10-18-2004, 09:06 PM   #17854
InitialD's Avatar
I guess those problems are setup problems that needs to be adjusted. Are you using a lot of spacers in the outdrives to take out most play in the dogbones? I think with the front diff with the trackwidth set up to 198 mm, you may not need to put any fuel tubings in the outdrives when using Ellegi rims.
I guess the reason why the hexes feel tight is due to the hole being very tight fitting. I use a bodyshell reamer to ream the plastic out a little when they are new out of the box to make the hole slightly bigger diameter. It fits perfect.
I find that the Ellegi rubbers last much longer than Speedminds for the same traction.
It was already mentioned earlier that the Ellegi tires will make the trackwidth about 1 mm wider than if you used Speedminds. For me, after I've set the trackwidth with the Ellegi tires (making sure no dogbones binding on suspension compression), I use lexan pieces cut out in the same shape as the hex to be used as spacers to space the Speedmind wheels back to 200 mm. A piece on each side of the wheel (on all 4 wheels) will suffice. One thing good about this is it spacers out the tendency of the Speedmind rim side rubbing the knuckles and making a groove.
Old 10-18-2004, 09:54 PM   #17855
So know, they were using same offset as "good-cheap, A-main World" tire ?
GoldFinger is offline   Reply With Quote
Old 10-18-2004, 10:00 PM   #17856
sparksy's Avatar
I dont use any spacers for the outdrives or dogbones.
I guess it depends on what diameter you run the tire too. I like to run them at box height (1-1.5mm smaller front) due to the size of the track Picard and I usually run on. So for my large tire diameter and ride height of 4mm the dogbone doesnt have as much room as a smaller tire setup.
Old 10-18-2004, 10:02 PM   #17857
Pyramid's Avatar
.... on road dramatic mode is ON
Pyramid is offline   Reply With Quote
Old 10-18-2004, 10:11 PM   #17858
crashed_1's Avatar
Default Re: Re: My Winternats Weapon!
But you should see Uncle Crash's new 710 lock and loaded. But the only consolation is his JP FX engine is not as good looking as yours.
How'd you get your heatsink so clean and so BLUEEE???!!...
crashed_1 is offline   Reply With Quote
Old 10-18-2004, 10:37 PM   #17859
markp27's Avatar
Send a message via ICQ to markp27
Default Re: hey
Originally posted by impalabob64
mark ,i will be there with venom in me eyes with my super modified ns3 on 1 710,an jp on the other you an kve take the frt i bring up there.an when serpents hit the track this is the look we will get when they see the snakes run an u now this man
Sounds like a plan!
markp27 is offline   Reply With Quote
Old 10-18-2004, 10:39 PM   #17860
markp27's Avatar
Default Re: Re: Mysterious 17T copper gear!
Mark, perhaps that bronze coloured pinion is meant to be screwed down a lot more...
This is what I suspect, too, but it physically can't be screwed in any further - it is hard up against the 22 gear.
Old 10-18-2004, 10:43 PM   #17861
markp27's Avatar
Default Re: Re: Re: My Winternats Weapon!
You've probably forgotten by now, but that's its natural colour
BTW: Nice Avatar!
Old 10-18-2004, 10:45 PM   #17862
markp27's Avatar
Default Re: Re: Check this pipe out!!!
What about heat dissipation? The colour of the pipe alters the surface temp which alters the speed of sound in the pipe = performance.
Hmm, good point, the darker colour should mean more heat radiation and lead to a slightly cooler temp of the gases inside the exhaust - no idea how that affects the performance, though
Old 10-18-2004, 10:52 PM   #17863
markp27's Avatar
Oh nice ! No titanium screws? I'm dissapointed !
Obviously I'm not using Ti screws on this car, they are too heavy! instead these are Metal Matrix Composite screws much harder and lighter than the Ti screws, but to the untrained eye they look like standard screws, ehm, honest!
See how a naturally unfiltered pic can turn out? With no dirt filter on, the pic comes out naturally better ! Of course the car needs to be physically clean.
Don't know what you're implying
And why haven't we seen any pics of Lock&Loaded?
p/s: Don't forget to trim that Bluetooth / WiFi body post antenna !
but not too much
Old 10-18-2004, 10:54 PM   #17864
markp27's Avatar
Hey, isn't ceramic bearings in the car and in the engine illegal in the Winternats?
Start running in the engine. Slow and easy.
Ceramics are fine for the Winternats *phew* Don't worry, that engine is going to be run it Slow&Steady
Old 10-18-2004, 11:39 PM   #17865
InitialD's Avatar
Easy. Just get a brand new JP FX engine and sell that ugly one you have to ME !
