Old 10-13-2004, 12:46 AM   #17431
Default Re: Re: engine
Originally posted by markp27
MS is using one of the new Mega engines - Serpent will be selling these engines very soon.
Hi,
I have heard that the new Mega's will be released at different time's.
The.21 will be available in November, but the new .12 will be released around January
Bye, Thomas
840918001 is offline   Reply With Quote
Old 10-13-2004, 12:49 AM   #17432
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Titanium screw set for 710
Originally posted by 840918001
Hi,
If you want to lighten your car I would use the Alu screws made by Serpent.
I have them all over my car and they are stronger then the steel one's.
Bye, Thomas
Stronger than steel I can't believe that the Alu screws are stronger than the steel ones.
markp27 is offline   Reply With Quote
Old 10-13-2004, 12:53 AM   #17433
Default Re: Re: Re: Titanium screw set for 710
Hi,
The first time you build the car, and screws will be done in the bulkheads etc, use the steel one's to pre-tread the holes.
Then you take those out and replace them for the Alu one's.
I never had any problem with them.
While I have stripped several steel screws, specially the allen type.
Bye, Thomas
Old 10-13-2004, 12:56 AM   #17434
Default For sale
Hi,
For all European racers, check out:
www.serpent.at
They have lots off for sale activities.
They also have Collari tuned .12 Sirio's
Bye, Thomas
Old 10-13-2004, 01:19 AM   #17435
InitialD's Avatar
Thomas, if I'm not mistaken, the Serpent aluminum screws are M4... No?
Old 10-13-2004, 01:25 AM   #17436
InitialD's Avatar
Default Re: For sale
I saw that they have Collari LC engines but Sirios mod engines by Collari? Where?
Old 10-13-2004, 01:45 AM   #17437
Salvens 710 at the worlds taken by Mike Meyers
PhatPat is offline   Reply With Quote
Old 10-13-2004, 03:19 AM   #17438
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Ok thanks i'm used to see purple cooling heads for the novamegas thats the reason i've asked anyway any idea how much will it cost
buboy28 is offline   Reply With Quote
Old 10-13-2004, 03:31 AM   #17439
Hi, about the new servo saver...is it better for all tracks? or just for some, fast, technial etc.
Does it give a smaller steering radius, or more/less ackerman?
Thank you
Finken is offline   Reply With Quote
Old 10-13-2004, 04:46 AM   #17440
KevinS's Avatar
Red aluminum front upper arm brackets?
EDIT
Nevermind, it was discussed earlier.
KevinS is offline   Reply With Quote
Old 10-13-2004, 05:03 AM   #17441
KevinS's Avatar
Aluminum-beryllium is.
I don't want to pay $10 per screw though...
Anyway, I'm using a lot of Al screws (from www.fastener-express.com) on low stress areas in the car without problems. That includes al M4's. I haven't had the guts to try them on the shocktowers, shocks, steering etc.
Recently I replaced all those screws (high stress) with Ti. The car has no symptoms of rejection of the Ti screws so far, which is remarkable since they are made by Mugen.
Old 10-13-2004, 06:37 AM   #17442
rcpanama's Avatar
Smile
Hi like to explain a problem I had with my first 710.
I have two 710 one (first) have a fuel tank with a white filter and the other (second) have a fuel tank with a copper fuel filter.
I had a problem with the first one (white filter) last wee, the engine will stop as soon as I stop the car I change the three engine with the same result, at the en I change Fuel Tank (my spare tank is with the old white filter) and problem solve.
Now few month ago in MYTSN there was an issue of a problem with this fuel tank but it was in German so I really donít now what was the problem.
I started using on my last Gallon of Byron 20% / 12% fuel the additive NITRO BLAST.
My question is, could it be that my problem is due to the tank failure (white filter) or cause by the Nitro Blast in the fuel?
Thanks for any feet bank on this issue.
rcpanama is offline   Reply With Quote
Old 10-13-2004, 06:44 AM   #17443
markp27's Avatar
Default Re: Re: Re: Re: Titanium screw set for 710
Hmm, but what happens if you have a race with a Mugen - maybe suddenly the screws will be suddenly attracted to the Mugen car :O
Did you buy the screws individually or simply the bag of screws for the MTX-3?
Old 10-13-2004, 07:06 AM   #17444
Sow&Steady's Avatar
Aluminum-beryllium is.....
Am-Be is radioactive but I don't know about Al-Be. Wouldn't THAT be cool! "Nuclear powered" 1:10th Nitro Car!!!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-13-2004, 07:30 AM   #17445
Pyramid's Avatar
Default Re: engine
Originally posted by buboy28
guys, what engine does michael salven is using at the worlds? thanks
http://3hobby.com/modules.php?name=N...rder=0&thold=0
Looks like 3hobby is moving faster nowdays
Pyramid is offline   Reply With Quote
