Serpent 710
Old 10-09-2004, 02:33 PM
  #17266
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Normal service is resumed
Originally posted by markp27
You would have a point there, if you weren't called Sow
OK ...Steady then!
Sow&Steady is offline
Old 10-09-2004, 02:36 PM
  #17267
Sow&Steady's Avatar
Default Re: Re: Re: Interesting info
Thanks Marcos - it was posted a couple of pages back, too.
Something else which is interesting is the position of the forward most body clips - they aren't even touching the body!! Only the third body post is actually holding the body down. Any reason for this?
Yes ... the most likely reason is that while they're testing the set-up, they'll want to also see if the shocks etc is not too soft or hard.
Too soft and the chassis bottoms out. When this happens, they don't want the body to scrub on the track. The shell can ride up the body posts a little bit mounting them this way.
Too hard and the car will be bouncy ... easier to see the "bounce" with the shell loose.
Old 10-09-2004, 02:48 PM
  #17268
markp27's Avatar
Default Re: Re: Re: Re: Interesting info
markp27 is offline
Old 10-09-2004, 02:59 PM
  #17269
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Interesting info
Don't bow too quick.
a) This is just what I do and I think they like to do too and
b) you should only bow to a "prophet"
Old 10-09-2004, 05:15 PM
  #17270
it
it's Avatar
Default just wondering!!
Any of you guys tried the Delta clutch shoe for your 710? Was that clutch has longer life than the stock one? Or better performance than the stock one?
it is offline
Old 10-10-2004, 03:21 PM
  #17271
Sow&Steady's Avatar
Default Re: just wondering!!
What is a delta clutch?
Old 10-10-2004, 03:31 PM
  #17272
Herbie's Avatar
Default Re: Re: just wondering!!
Sow it's a clutchshoe made by Delta just as JPRacing made a red one also. There seems to be some kind of material used in the shoe for endurance. Don't know the name of the stuff used
http://www.jpracing.com/ang/nouveautees/index.php
Herbie is offline
Old 10-10-2004, 03:46 PM
  #17273
Sow&Steady's Avatar
Default Re: Re: Re: just wondering!!
Oh I see. Never heard of Delta before. Can you buy it online somewhere?
Old 10-10-2004, 10:40 PM
  #17274
In electric touring scene, most of driver do that. Mount the clip loose (1/2 - 1 hole above body).
The purpose is, when they touches other car (or curbs) only the shell is move up a bit, not the car.
GoldFinger is offline
Old 10-11-2004, 12:20 AM
  #17275
InitialD's Avatar
Mark, look at the latest Michael Salven's body. Now he spots a a front hole in the front of the wind screen.
While Josh Cyrul's bodyshell spots a partial hole in front and a unique side window cut. I think that strenghtens the front body part more and less body flex.
InitialD is offline
Old 10-11-2004, 12:29 AM
  #17276
FW-05RR's Avatar
Hey D can you post the link where you are getting these beautifull pics
thx
FW-05RR is offline
  #17277
B4
B4's Avatar
Default Re: Re: Interesting info
Originally posted by Marcos.J
here is Salvens car in Brazil!
Anyone notice how far back the rear wing is positioned.
B4 is offline
Old 10-11-2004, 12:30 AM
  #17278
InitialD's Avatar
Starting Grid
InitialD is offline
Old 10-11-2004, 12:35 AM
  #17279
InitialD's Avatar
Crashed_1 mentioned to me that it is a possibility that since the rear wing needs to be cut thinner for legal reasons (refer to the rear wing marks and you'll know what I mean), you will see as if the wing is mounted more towards the rear as he will need to use the rear part of the mounting hole on the body to align the rear hole made on the wing.
InitialD is offline
Old 10-11-2004, 12:41 AM
  #17280
B4
B4's Avatar
I have my wing cut to the lower marks on the wing and it is mounted so the rear of the wing is level with the rear of the body. This is not causing a problem, improves front traction.
B4 is offline
