Old 10-07-2004, 02:58 AM   #17071
Picard's Avatar
Default Re: Re: Rear Roll centre
Originally posted by InitialD
I would think so...
I think the current rear RC that you have now is slightly lower than stock. Some tracks prefer a lot of camber change while others not. The shorter rear upper arm (UTO or UBO) gives more camber change upon suspension compression. The stock rear RC and the currect RC that you're having now is the long rear arm version which gives less camber change.
Like I mentioned earlier, the RC would depend a lot also on your overall setup. I would look into the other stuff first before playing with the rear RC. If the rear is loose, I would tighten the front sway bar some more. Make it more stiff. Less rear droop. More rear camber.
Yep tried all of those D, ven the shorter arm, track prefers the longer arm
I am fairly sure it is the clutch, but if I can get it to stick the car will be near perfect for me.
My problem is if i go back to the higher roll centre, I cant see it working any better? Hopefully I am wrong
Picard is offline   Reply With Quote
Old 10-07-2004, 03:00 AM   #17072
Picard's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: New Track
Relocate geographically ! Down Unde is not a bad place to retire.
Old 10-07-2004, 03:03 AM   #17073
crashed_1's Avatar
Default Re: Re: Re: Re: font belt issue
How is the front belt so far? Any problems?
The only observation i can see so far is the belt tension remains consistent with the alu mid bkt...
crashed_1 is offline   Reply With Quote
Old 10-07-2004, 03:05 AM   #17074
InitialD's Avatar
Default Re: Re: Re: Re: Re: font belt issue
Resist temptation !
Old 10-07-2004, 03:08 AM   #17075
InitialD's Avatar
Default Re: Re: Re: Rear Roll centre
You could try... I thought Pyramid mentioned before that the higher rear RC worked better in terms of rear traction.
Old 10-07-2004, 03:08 AM   #17076
Default Re: Re: Re: New Track
Hi Brett
Yes you are correct on all counts, the track was fantastic, had a lot of fun last night. Very impressive setup
Thinking of comming over in 05 any big events i should look out for?
Brett.w is offline   Reply With Quote
Old 10-07-2004, 03:09 AM   #17077
Send a message via Yahoo to speedy100
Default Re: Re: new serpent kits 710
speedy100, if you've a serious race to go to and you want to make sure you have the strongest parts on the get go, then by all means get the parts separately.
If you're casually playing and racing at club level, I suggest going with the stock parts first and when you break them, then you could replace them with parts that are with stronger plastics which is a running change that Serpent is doing.
D, i rarely run my 710 but I found the pastic parts has been fatigued and there were some movement and not in place.
speedy100 is offline   Reply With Quote
Old 10-07-2004, 03:12 AM   #17078
InitialD's Avatar
Default Re: Re: Re: new serpent kits 710
Which parts are you referring to?
Old 10-07-2004, 03:42 AM   #17079
Default Re: Re: Re: Re: new serpent kits 710
D, I am referring to the front upper and lower arms, the rear lower front arms also but not noticeable like the front arms.
Old 10-07-2004, 03:59 AM   #17080
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
Look at the JP website ! The newer fanged 3 port sleeved JP FX engines are touted to be having the same horses as a 5 port !
Oh dear, where have you been my firend. Need to borrow the ring?
I've been saying this to NiMo for a while too and you can see it in his engine's performance. Not sure about Mark's because he has the old fangs. I better check mine this weekend, the guy at the Border promised that its got the new fangs.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-07-2004, 04:00 AM   #17081
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
Originally posted by markp27
Ehmm.......
I found my best entry into the chicane was from a shallow angle at the first apex, which meant I didn't really have to steer right at the first apex and at the mid part of the chicane, I only needed a little bit of steering input to the left before coming out and turning right.
If you see what I mean?
That's what I normally do but I find that if I'm following a couple of the faster guys, that's where I lose ground.
Old 10-07-2004, 04:01 AM   #17082
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
You tricked me into revealing that
Old 10-07-2004, 04:02 AM   #17083
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
Let's just hope that Sow tries it out
Old 10-07-2004, 04:03 AM   #17084
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Vidz
Nice one there Mark...I Like!!!!
I hope you liked the laughing dog and not the metal fence!
Old 10-07-2004, 04:03 AM   #17085
Sow&Steady's Avatar
That gif file reminds me a lot like... Onkel Sow !
