Old 09-28-2004, 09:30 PM   #16501
InitialD's Avatar
Default Re: Re: Re: Re: Optional Servosaver Arm
Originally posted by Sow&Steady
You might be right, it was my rear ones (the original and now the Ti) that seems to wear quite a bit. Maybe I need to "punch" on the throttle less.
What kind of weather are you having there? You seem to be wearing out a lot of things.
No problems with the Ti 2 speed shaft from 3Racing.
Old 09-28-2004, 09:32 PM   #16502
InitialD's Avatar
Originally posted by sn4il
Yeah, i need it ASAP.
PM Goldfinger or Pyramid. They might be able to hook you up with one.
Old 09-28-2004, 09:32 PM   #16503
InitialD's Avatar
Default Re: Re: Servo Saver
Originally posted by KevinS
It's just the arm on which the trackrods are mounted that's new (longer). The number is 802146 for just that one part. 802143 is the original set of all nylon parts in the servo saver.
Yeah... And if you're using the front ball diff, you need the newer 2 piece diff adjuster too That's why it is packed together with the new servo saver in 802145.
Old 09-28-2004, 09:33 PM   #16504
InitialD's Avatar
Default Re: Optional Servosaver Arm
Originally posted by sparksy
So who has fitted this? Has anyone else found it causes the origional part of the assembly (the arm that the servo link attatches to) to hit the left hand bulkhead?
I do not have the new servo saver. The only thing Serpent mentioned about it is if you're using the front ball diff with the new servo saver, you need to use the new style 2 piece diff ring. But your problem with the servo link hitting the left hand bulkhead is new to me. Perhaps too much steering lock?
Old 09-28-2004, 09:38 PM   #16505
Sow&Steady's Avatar
If you email mushroom they may be able to get you one. They told me they could get almost everything in the serpent range.
The out drives I'm talking about are the hudy steel ones from the 705/835. The ones with the 4 slots.
Oneway Outdrives
Wheel Axles (fit front and rear)
The Oneway Outdrives must be tough to drill properly for the lock pins though right?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-28-2004, 09:39 PM   #16506
Sow&Steady's Avatar
Originally posted by InitialD
808223.
Onkel Sow, I think you were sleeping when Onkel Sparsky gave tips on what he did to his 710 late last year way before Serpent came out with the options...
You're right ... I was definitely asleep!
Old 09-28-2004, 09:40 PM   #16507
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Optional Servosaver Arm
I don't think it has anything to do with weather ... its my shaky fingers and hands!!!
Old 09-28-2004, 09:41 PM   #16508
Sow&Steady's Avatar
Default Re: Re: Re: Servo Saver
That's right, otherwise the nes servo saver won't fit.
Old 09-28-2004, 10:24 PM   #16509
sparksy's Avatar
Trader Rating: 14 (94%+)
I dont run my oneyay locked so I havent drilled them. I just cut them shorter so they fit.
I've tried the front locked but found the front diff better.
I havent posted a pic in a while...
And one for Mark showing the 1st gen rear tower...
sparksy is offline   Reply With Quote
Old 09-28-2004, 10:37 PM   #16510
Sow&Steady's Avatar
[B]I dont run my oneyay locked so I havent drilled them. I just cut them shorter so they fit.
I agree with you but Murphy's law says the day I can't lock is the day I'll want to do a quick lock instead of using the diff.
Old 09-28-2004, 11:25 PM   #16511
redsand's Avatar
Send a message via Yahoo to redsand
Default new rear bars
I found out that when using the new rear swaybar, the ball ends on both side have to be pushed 2 mm in. Otherwise the rods rub the dogbones.
redsand is offline   Reply With Quote
Old 09-28-2004, 11:43 PM   #16512
markp27's Avatar
Send a message via ICQ to markp27
Default Re: new rear bars
Rear Anti-Roll Bar
markp27 is offline   Reply With Quote
Old 09-28-2004, 11:50 PM   #16513
AMGRacer's Avatar
Man thats one UGLY car........................
AMGRacer is offline   Reply With Quote
Old 09-28-2004, 11:54 PM   #16514
markp27's Avatar
This is getting silly now - can this really be down to a manufacturing fault or are we too incompetent to break parts which were intended to be broken
Old 09-28-2004, 11:58 PM   #16515
InitialD's Avatar
That's one handsome car you have sparsky! I'm sure Mark appreciates the rear shock tower pic very much.
