Old 09-13-2004, 06:56 AM   #15586
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by InitialD
One of the best "naked" pics of the 710.
Taken with a D2H Nice!
markp27 is offline   Reply With Quote
Old 09-13-2004, 07:03 AM   #15587
sparksy's Avatar
Trader Rating: 14 (94%+)
Mark, run a drill bit down the hole to clean up some of the anodizing. It will stop the binding.
sparksy is offline   Reply With Quote
Old 09-13-2004, 07:24 AM   #15588
markp27's Avatar
I was thinking about this, but was a bit reluctant just in case it was due to something else.
Thanks, Mark.
Old 09-13-2004, 07:27 AM   #15589
markp27's Avatar
Default 710 German Champion - Michael Salven
Well even though this was at a track only 3/4 of an Hour away from me, I didn't get to see it due to other commitments Check it out though, Serpent 710 1,2 and 3!!!!!!
http://www.mytsn.com/news/publ.asp?pid=10624
Old 09-13-2004, 07:30 AM   #15590
Picard's Avatar
Mark
That is what I have done to mine and it is fine, be sure to do it slowly as it does not require much to free it up
Picard is offline   Reply With Quote
Old 09-13-2004, 07:31 AM   #15591
sparksy's Avatar
Thanks, Mark.
I think they machined the hole to the correct size, but the anodisig process adds a small amount of particles to the surface, making the hole a little smaller.
I would insert the drill fully in the hole before spinning it slowly. Just to clean up the hole a fraction.
Old 09-13-2004, 08:06 AM   #15592
markp27's Avatar
Thanks for the advice, guys! Makes sense with the anadizing!
Old 09-13-2004, 08:53 AM   #15593
Pyramid's Avatar
Let me try to confuse you again if without filling/polishing and screwing the holder to its arms, just slide tye holder over the arms shaft, does it bind? if not, r u sure you want to make a slopes on that holder holes? That was I did with my 3racing one, and later I realize the one with bushing (well, 3racing comes both with bushing) will gives different slopes at different eccentric angle placement...
Pyramid is offline   Reply With Quote
Old 09-13-2004, 08:57 AM   #15594
markp27's Avatar
Good you mentioned this Pyramid - forgot about that. When I place the alu arms on the pins, they move very freely indeed. The suspension arms only bind after I've put the fastening screw in But even if I loosen it off a little, then it still binds.
I'll take another look at it before starting any material removal
Old 09-13-2004, 09:22 AM   #15595
Pyramid's Avatar
As far as I could remember, I believe they drill the holder holes after anodizing it, don't they?
Old 09-13-2004, 10:05 AM   #15596
markp27's Avatar
Just check. The serpent ones are still anodised within the holes.
Also the 3mm drill passes through the hole no problem - it wouldn't take any material off, but may wear down the anodised coating.
Old 09-13-2004, 10:16 AM   #15597
Suspended
Default one piece engine block
serpent has just released the new one piece monoblock engine-and guess what..its orange....(one piece engine block)
SERPENTFREAK69 is offline   Reply With Quote
Old 09-13-2004, 10:18 AM   #15598
Diesel Racer's Avatar
Default Re: Re: Re: 710 will defitely go even quicker now!
Originally posted by Sow&Steady
WinterNats, want to join us?
Wish I could but as you saw on Sunday I'm not quite quick enough, and with the move to Spain I just won't have the time but most importantly the guvner won't allow it.
Diesel Racer is offline   Reply With Quote
Old 09-13-2004, 10:33 AM   #15599
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Default Re: one piece engine block
Anyone got a picture of it? I can't find it on the Serpent site. Thanks.
Blue Sky is offline   Reply With Quote
Old 09-13-2004, 10:35 AM   #15600
sparksy's Avatar
Thats all I did... just enough to free it up, without taking aluminium off... just the anodising.
