Old 10-30-2003, 02:05 PM   #1
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
Default hpi rs4 3 ss thread
just wanted to start a thread on this car since we dont have one...all you people that have these cars..or know good set up's for the car, tires etc...please post
2mcgrath is offline   Reply With Quote
Old 11-02-2003, 05:55 AM   #2
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
I know a good set up..... BUY A MUGEN MTX-3!!!!!! ahahh
mtx3racer is offline   Reply With Quote
Old 11-02-2003, 06:46 AM   #3
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
you'll be better off going to a forum that has specific threads..
http://www.radiocontrolzone.com/foru...hreadid=124363
And I wouldn't buy a MTX3 either...stay with the HPI family and get the r40 if you want a pro car...
MY SS(with RB turbo) runs really well also....but is really more of a club/parking lot racer......
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 11-02-2003, 08:26 AM   #4
im getting ready to start racing mine some thats why i wanted to hear from people that knew good setups and stuff like that and the track i will be running on is a small road course..and as for the mugen i have seen it get beat at the track by ntc3's and hpi's..i think as long as you got a car that handles allright its about the driver of the car and how good he can drive it..not how much the car costs.
Old 11-03-2003, 10:50 PM   #5
come on guys someone has to know something about getting this car setup some ideas.. i know im not the only person that owns one..i just hit on a great gear ratio today for the car and it works awesome..i dont care if the mtx 3 is better or what not you have to pay out the a$$ to own one if you know what i mean..
Old 11-03-2003, 11:01 PM   #6
rodrigo1508's Avatar
I own one and have a lot of money on hop ups on it and I have raced it but to be honest this car is not for racing If you have it all stock It will be beaten rhe engine is not that great and its set to high I just didnt like it I did won a 3rth and 1rst on my local track with it but with all the noobs, thats why I bought a r40.
But to answer your question here is the set up that hpi gives:
Dedicated on-road track, smooth surface, high grip, large size
Front
Pink Pro Linear springs (#6759)
40wt Team Orion shock oil
#3 piston setting
Firm shock bladder (#72112)
Lower arm mount hole "A"
8 degree C-hubs
Woven graphite shock tower (#73047) hole #1 top, hole "L" bottom
4.5 mm ride height
2 degree camber
Team Orion foam tires 37 shore (26mm)
Front C-hubs were modified by cutting off camber link mounts and using #A317 Rod Ends at the end of the turnbuckles instead of stock ball cups. Insert a #A132 Ball pivot in each rod end, then use a #Z059 countersunk flat head 15mm titanium screw to attach the ball/rod end where the top kingpin normally goes (the stock hex cap head screw). The effect of this modification was to make the turnbuckle "captured" and allow better camber change as the suspension compresses.
Rear
60wt Team Orion shock oil
#3 piston setting
2 degree hubs, hole #1
Woven graphite shock tower (#73048) hole #2 top, hole "L" bottom
5.5 mm ride height
2.5 degree camber
Team Orion foam tires 37 shore (30mm)
Rear turnbuckle connection to uprights modified similar to front C-hubs, except the uprights were not modified. This was to add a "captured" end to the turnbuckle.
Engine
Novarossi MR12 rear port SG shaft
Associated header
Novarossi 6802 pipe
McCoy MC 59 plug
HPI Power Fuel 30% fuel
Yokomo 3 shoe clutch (for SG shaft)
Yokomo flywheel/collet (for SG shaft)
Wolfpack Radicals adjustable engine mounts (WLF054)
Body/wing
HPI Stratus 200mm body (#7416)
Touring Car Wing set, 195mm wing (#7115)
Transmission
18/23 pinion gear (#76978/#76983)
39/43 spur gear (A445/#76843)
Wolfpack Radicals clutch type 2 speed (WLF061)
Gear box
Front one way (#86122)
Heavy Duty Gears for rear diff (#A856, #A857)
50,000 wt rear diff grease
Other
Wolfpack Radicals steering cranks (WLF065)
Fiber Brake Disk #A844 for more consistent braking, place fuel tubing between the brake plates (on the screws) for consistent action
Good luck racing!
rodrigo1508 is offline   Reply With Quote
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
