Old 11-04-2003, 08:59 PM   #31
prawntoe's Avatar
Originally posted by InitialD
Thanks for the info prawntoe. You're the STS engine expert !
Ummm, the front end bearing (and hence crankshaft) of the D5 and D3 are not interchangeable then?
oh sorry if I was unclear in my reply.
I reread your msg. .
I meant to say 7mm/7.5mm BORE as Stefan mentioned.
sorry.
prawntoe is offline   Reply With Quote
Old 11-04-2003, 09:07 PM   #32
InitialD's Avatar
Originally posted by prawntoe
internal dimension of the bore is different (outlaw vs legal) but external dimension of RS/D3/D5 are the same, thus they are interchangeable.
Ummm, you mentioned that for the D5, the crankshaft diameters are 12mm/7.5mm while the D3 diameters are 12mm/7mm... So, they are not interchangeable then?
12mm ID bearings (internal) are ISO standard, therefore can be replaced with standard bearings. . .
front bearings should be the same and interchangeable with Nova based engines.
Yes, that is correct. The "older" non NS Novas that is...
Old 11-04-2003, 09:21 PM   #33
Nitro Tech
dino.tw's Avatar
Default Re: DRAGON conrod
Originally posted by smartdriver
Well,I broke my Dragon in as per the sheet and had my first race with it and now the conrod is worn out and the piston has some ugly discolorations in one spot on the sleeve.My engine didnt come with an extra rod
so I guess I have to buy another one.....
By the way Im not some kid who doesnt know what he is doing.
not happy at all......Guess I need to stick with Novarossi based stuff....
Anyone unhappy? Oh~~It's my trouble.
Well,Dear SmartDriver,
Please let me know some question;
1)How many fuel have through this engine?
2)Please measure the crankpin size and conrod bushing then let me know.
Fron your statement,your engine is a bit too lean.
When you see some ugly discolorations on the sleeve or piston,that means your engine temp. was about more than 280F.
dino.tw is offline   Reply With Quote
Old 11-04-2003, 09:24 PM   #34
prawntoe's Avatar
[i]Yes, that is correct. The "older" non NS Novas that is... [/B]
Never measure one myself but I think the front bearing for both ns12S(x) should be same as "old Nova" ??
only the internal bearing is different (ID 11mm vs 11.5mm).
Old 11-04-2003, 09:34 PM   #35
InitialD's Avatar
Front bearing is 7x17x5 and inner bearing is 11.5x21x5 for the NS. For the "older" RS, the front bearing is 7x19x6 while the inner bearing is 11x21x5.
Old 11-04-2003, 10:33 PM   #36
prawntoe's Avatar
good to know we have novarossi expert in Malaysia !!
Old 11-04-2003, 10:43 PM   #37
InitialD's Avatar
Novarossi expert? Naah... Novarossi sponsored would be nice !
Old 11-05-2003, 04:37 AM   #38
stefan's Avatar
Send a message via AIM to stefan
Default Re: Re: DRAGON conrod
Dino,
the engine never got hot.
I checked and adjusted his D5 before and after each run and the temp never went over 230 degrees.
So, what's your alternative theory.
Oh, and btw, you are correct, if your customers are unhappy, you are in trouble. No need for dumb "smileys" in that statement.
stefan is offline   Reply With Quote
Old 11-05-2003, 05:53 AM   #39
Manticore's Avatar
R/C Tech Charter Subscriber
It is good to see people from the industry to provide users support. I wonder if Dino is either being stupid enough to let unhappy user to shout at or he tries to help people out here. think about it.
Manticore is offline   Reply With Quote
Old 11-05-2003, 07:44 AM   #40
Well, my personal opinion is that it's definately value for money as I have used both RS5 and now the D5.
We used to see Dino sounding quite apologetic every other day when RS5s were giving alot of problems but nowadays with the D5 he sounds more relaxed :-) and surely alot less complains from users. so that's surely a sign of quality improvement.
My D5 was able to give the Rodys a good run for the money. .
ed
Originally posted by stefan
I have not seen smart drivers conrod after last weekend, so I cannot comment on that, but what I can say is, that I was not very impressed with the power it made.
I'm used to fast modifieds like Murnan's and my own ones and the D5 felt rather average on the track.
I drove smarty's car in the main (because the whimp had a headache ) and wasn't impressed at all.
We were both thinking about replacing the 6.5 mm carb with a 5.5mm Nova Rossi carb.
I'm going to brak in my D3 soon and I will watch the rod closely and report.
racerchan is offline   Reply With Quote
Old 11-05-2003, 08:18 AM   #41
Fisher890's Avatar
Well,
I'm gonna go ahead and lay my Money down if nothing else I know these guys have great customer service and if I have any probs they will be on it. That makes it worthwhile for me. I know I won't be pushing any limits on it for quite awhile anyways. What confused me on the Cranksize issue was the advertised crank spec. 7mm for the D3 and 7.5 for the D5 where all the other motors advertise a differant crank spec of 11.5 mm. I didn't notice that they were talking about 2 entirely differant measurements.Thank you for your patience in my research.
Fisher890 is offline   Reply With Quote
Old 11-05-2003, 09:20 AM   #42
Nitro Tech
dino.tw's Avatar
First I have to thank you for all of your support.I'm sorry if I let you feel bad.For those smileys,I just want to let you know that I care about you.There is no malice.Please treat me as a friend although I'm working for STS.It hard for me to help smartracer by only a few statement.I really want to help but I need more details.
Old 11-05-2003, 10:48 AM   #43
Nitro Tech
dino.tw's Avatar
By the way,this afternoon I went to track and tuning the D5 engine for a customer.Because he never tune it well and want to change a new one.I checked all the internal parts and found there is no any wrong.So I thought the problem is on tuning.I drove about 30km to the track and tuned the engine for him because I do care.Let me tall you what I do.
First I found his engine is easy to die out on low-mid revs.His car is LD3 with RDLogic pipe.As my experience with this RDLogic pipe for NTC3/LD3,I made the pressure-line about 27cm.It's better now but still easy to die out.
Then I rich the low-speed needle for cooling and tuning the 2-speed for him.Because its 2-speed is too fast and make him feel that there is no punch,so he leaned the low-speed needle very much.I make the low-speed needle about 5 turn out,and check his car carefully.I found his throttle can't open fully,asking him to adjust the radio system.Also put 2x o-rings under the fuel tank for him to reduce shock.Now the car was better and better,but when he stay for a while and full throttle suddenly the engine still die out.
The last step I decided to advance the ignition timing.I take out 0.2mm head shim,only keep the 0.3mm silver head shim.Well,everything is perfect now.It seems D5 requires lesser head shims.The engine is very fast(250F).Never die out no matter how he play and has stable idle.I can see the smile on his face now,but you know what?I'm happier than him.Your smile is mine smile.
Maybe I should fly to LA to tune the engines for you.My sister lives in Alhambra.
Old 11-05-2003, 10:57 AM   #44
Send a message via AIM to loosenut
Default Re: Re: Re: DRAGON conrod
Dino,
Hey take it easy there bro. Give Dino a break since he doesn't speak (or type in this case) English fluently. So I would read his threads with that in mind. As far as I know, he's been super cool to deal with and very helpful on this forum. Maybe there's some culture differences here in the way people use smileys.
I presume that most of you are very experienced rc car hobbyists (so it appears). So you should know that conrod bushings will wear more during breaking and run in process and sometimes will need to be replaced. It's recommended by any experienced drivers to replace the conrod after break in or maybe after 1 gallon. Just change the conrod. I'm sure there's always a couple of bad eggs in the basket - so that may be the case. Again, just change the conrod - what's the big deal? Maybe the engine has not fully broken in yet that's why it didnt' perform at its optimal. Bottom line, there's alot of variables and assumptions here. All in all, take a look at how much you PAID for the engine.....
G
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 11-05-2003, 11:08 AM   #45
Dino,
It's nice to know that you are so passionate about satisfying your customers. But it's hard because there are so many variables or possibilities involved here...and on top of that, there are going to be people complaining no matter what! That's just the nature of teh beast.
You just can't beat bang for the buck when it comes to STS engines.
G
Are Hyper 7, 8, 8.5 parts interchangeable? Paul Whalen Nitro Off-Road 5 07-22-2008 12:01 AM
Are parts from Hyper 7, 8, and 8.5 interchangeable? Paul Whalen Electric Off-Road 1 07-21-2008 05:25 PM
OS VZ-R/VZ-B Conrod and Nova P5 Conrod rod_b R/C Items: For Sale/Trade 2 03-21-2006 06:58 PM
interchangeable parts for the xxxbk? Stevietd14 Electric Off-Road 4 09-24-2004 06:45 PM
xx4 and XXX4 PARTS INTERCHANGEABLE? xaznriceracerx Electric Off-Road 2 09-24-2003 11:19 AM
