ntc3 w/ slide carb >
ntc3 w/ slide carb
ntc3 w/ slide carb
Old 01-14-2009, 05:58 PM
ROADRASH77's Avatar
Trader Rating: 30 (100%+)
Arrow ntc3 w/ slide carb
i'm putting an rb v15 on my ntc3. i need to nkow if there is a kit to convert to slide carb or just make something yourself.
thanks
ROADRASH77 is offline
Old 01-14-2009, 06:01 PM
helivaguy's Avatar
Trader Rating: 42 (100%+)
here ya go...
http://aedownloads.com/pdf/ntc3_linkage.pdf
helivaguy is offline
Old 01-14-2009, 06:04 PM
ROADRASH77's Avatar
THANK YOU
Old 01-14-2009, 09:38 PM
BUDRACER1's Avatar
Trader Rating: 38 (100%+)
Just be sure to angle your carb so that when the servo pulls its not binding.On my OS engines i rotate the carb counterclockwise about as far as it will go.
Jason
BUDRACER1 is offline
Old 01-15-2009, 08:03 AM
I also found using the 3 arm servo arm of ofna's helps with not having to turn the carb as much.
http://www3.towerhobbies.com/cgi-bin...&I=LXLMW2&P=SM
bgrick is offline
