Which engine is better?
Which engine is better? Murnan or Smeltz modded. Which lasts longer? Performs better?
engine
For me M. Speed modified
Mod motors have a limited life expectancy. Length of life depends on the temps you run it. Most mod motors only like to run hot 280F-310F, so they are only tight for short while before needing a little squeeze and a new rod. But if the maintenance is kept up they will last you quite a while.
Never seen a Smeltz personally. I have seen about 10 or so of the Murnan's and they are quite fast. Have yet to see one blow up too. I am thinking about getting a Murnan MT12.
Modded motors have better mated piston and sleeve, more like less like matched perfectly so you get all the power from one combustion meaning more power. Of course all the work on crank, sleeve will also work with the force generated by the combustion!
Just my $0.02
I ran a Murnan modded X12 almost all season long and it didn't give me any trouble, only ballistic speed.
Ah10 and Topgun777:
I did not say all mod motors did I? I said MOST mod motors only like to run hot. Because that has been my personal experience with heavily modded .12 motors.
Ah10 and Topgun777:
Ah10 and Topgun777:
Ah10 and Topgun777:
Ah10 and Topgun777:
Originally posted by dtm
Which modded engine did you run which need the high temp? would be interesting to know so as to avoid buying?
Ah10 and Topgun777:
Ah10 and Topgun777:
Ah10 and Topgun777:
Ah10 and Topgun777:
Then I guess someone should call JP and tell them how to mod engines correctly.
Well Barry Baker is now running a Murnan Modified.
