Old 01-11-2009, 02:30 PM   #1
cupton79's Avatar
Default best 26mm tires for grip on asphault
I need suggestions on the best tires that have the most grip that will work good in a parking lot.
cupton79 is offline   Reply With Quote
Old 01-11-2009, 03:11 PM   #2
revo523's Avatar
I use nitro shoes for parking lot racing the shore you will have to make your own judgment, i will start with 40 upfront and 38 in the rear.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 01-11-2009, 04:32 PM   #3
cupton79's Avatar
the parking lot I run on is kinda rough and dirty, I was told that foams would just chunk up on a rough or dirty surface. is that true?
Old 01-11-2009, 04:40 PM   #4
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
they can chunk you could try a set and glue the edge to make it a little stronger. if you only bash use rubber tires
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-11-2009, 05:10 PM   #5
cupton79's Avatar
what are the best rubber tires to use?
Old 01-11-2009, 05:35 PM   #6
20 SMOKE's Avatar
if i was a basher,the cheapest one's i could find
Jamie W
Old 01-11-2009, 06:22 PM   #7
cupton79's Avatar
would a rubber racing slick work?
Old 01-12-2009, 05:14 PM   #8
Jspeed's Avatar
Ipanema dealers have access to belted radial rubber slick tires in sizes from 24mm to 30mm for 1/10 scale cars.
They're made the same rubber materials and construction as the bigger GT car tires and don't balloon.
Shore ratings of 35, 40, 45, 50 & 55 are available.
Here's Specs:
Corsa
Width 30 (mm) Diameter ext 67(mm) Profile 9(mm) Scale 1/10
Force
Width 26 (mm) Diameter ext 67(mm) Profile 9(mm) Scale 1/10
Pr
Width 25 (mm) Diameter ext 64 (mm) Profile 6(mm) Scale 1/10
Pr II
Width 24 (mm) Diameter ext 63(mm) Profile 5(mm) Scale 1/10
They are available pre-mounted and ready to race.
Check out the "where to buy" section on the Ipanema website to get them.
www.ipanemaracing.webs.com
Jspeed is offline   Reply With Quote
Old 01-12-2009, 05:20 PM   #9
revo523's Avatar
Here's Specs:
Corsa
Force
Pr
Pr II
I have used the Ipanema 1/10 tires and to be honest they dont last what so ever and the grip is not that great either.
Spektrum DX3S
Old 01-12-2009, 05:59 PM   #10
Jspeed's Avatar
That's very interesting Revo....
Which tire did you use?
What Ipanema dealer did you buy them from?
What shore tire did you use?
Old 01-13-2009, 10:45 AM   #11
afm
afm's Avatar
The best Rubber Tires for racing and or bashing 1/10th 20mm cars are PMT Tyres from Italy, they come premounted on rims, they are low profile, comes in 4 different shore hardness, and they have treaded and slick patterns.
We have been racing with them for the past 5 years in our Only Rubber class with excelent results, even with today high power engines...we've tried every single brand in the market, and nothing works well with nitro cars as PMT tyres, we race 1 hour mains and they hold their grip, in dusty parking lots and on preped surfaces.
I don't know who imports PMT in the states, but you should give them a try, you won't regret it.
AFM
afm is offline   Reply With Quote
Old 01-13-2009, 12:04 PM   #12
revo523's Avatar
I got them from the guy that handles the parking lot racing, to be honest i dont know what shore or anything but they felt really soft maybe thats why they didnt last and also affected the grip.
Spektrum DX3S
Old 01-13-2009, 12:05 PM   #13
revo523's Avatar
AFM
Amigo do you have a link?
Spektrum DX3S
Old 01-13-2009, 01:09 PM   #14
Jspeed's Avatar
It sounds like you may have used the Ipanema Sintec ProII tires. They are softer shore with soft foam inserts. This tire lends itself more towards 190mm cars and used by a few 200mm nitro drag racers for straight line traction.
For on-road racing use with 200mm nitro cars, the Corsa, Force & PRO tires with firm inserts work much better for you. Shore ratings should be selected by surface conditions, temps, chassis weight, race length & driving style.
Corsa
Force
Pr
Right now there are only 2 dealers in North America selling these 1/10 scale rubber slicks. Without knowing the dealer you got your tires from, there's no way to make it right.
Contact [email protected]
Old 01-13-2009, 01:22 PM   #15
afm
afm's Avatar
This is their web page
http://www.pmt-tyres.it/epages/Store...3&Locale=en_GB
AFM
