Old 01-06-2009, 11:59 AM   #1
Send a message via ICQ to dgill Send a message via AIM to dgill Send a message via MSN to dgill
Default radio interference
My buddy has a traxxas nitro 4tec and we just got it running again after years of not using it. It has the traxxas 2.5 engine with the easy start, and all the electronics are airtronics. everything seems to run fine but when you start to run at 40-50% throttle and up the steering and throttle start to glitch and sometimes loose control. Ive checked all the wiring and put new batteries and still no luck. any suggestions to what may be causing this and any possible fixes?
Thanks in advance
dgill is offline   Reply With Quote
Old 01-06-2009, 12:02 PM   #2
Send a message via Yahoo to motojon
what about new servos usually when that occurs its either low battery or the servos going out. When I would run cheapy airtronics 102 servo for throttle it would cause all kinds of havoc when it would start to go out
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 01-06-2009, 12:09 PM   #3
i told him to get a new steering servo anyways since that one is cheap and cant hold well in a turn, so that is something i will try. THe batteries are brand new on the receiver and controller so i know its not a low power issue.
Old 01-06-2009, 02:32 PM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
Sounds like like you might be getting interference from vibration. This happens when you get the engine up to a certain rpm and metal objects start to vibrate at the correct frequecy (27MHz)which will cause interference with your receiver. this is why it happens at half throttle. I would make sure you don't have any loose metallic objects on the chassis that are allowed to vibrate with the rev of your engine. Insulate them with electrical tape.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-06-2009, 05:56 PM   #5
wizby's Avatar
You said you put in new batterys, so they are alkaline cells? The holder that comes with an older traxxas are notorious for causeing glitches from bad connections. The spring loaded plastic holder is the cause of many runway cars. Replace the battery holder.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 01-06-2009, 06:13 PM   #6
thanks ill have him pick up a new holder tomorrow.
RC FLIGHT brading Manila Racers 23110 12-24-2015 07:23 PM
Getting started:Tip's,Trick's,Newbie's come here! xsxracing Rookie Zone 59 01-03-2009 10:57 PM
mamba vs novak sparkplug1288j Electric Off-Road 27 11-29-2007 02:05 PM
Is AM or FM better? jatoman1992 Nitro Off-Road 11 09-25-2007 08:14 PM
iRacingWerkz Nitro Fest II @ Turf City(GP Offroad race registration, 26th Aug 2007) iRacingWerkz Singapore R/C Racers 110 08-29-2007 06:58 PM
