Old 01-12-2009, 04:18 AM   #16
MikaR's Avatar
high nitro content and therefore too much compression results as high temperatures. Try to get the temps around 100C-110C, no more than 120C
get the 16% fuel and then re-tune the engine
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 01-12-2009, 07:28 AM   #17
Foxxrocket's Avatar
Do you run oil content in your nito fuel, and if so, what precentage?
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 01-12-2009, 09:56 AM   #18
MikaR's Avatar
Sure, it comes in the fuel, nothing extra added. It think it's usually somewhere around 11%
Old 01-12-2009, 06:56 PM   #19
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Thumbs up hot motor
Originally Posted by Bullz View Post
Hi, any expert here know how hot of temperature limit is the Inferno GT2? That day, my IGT2 reach 146 c !!! Is it too Hot? What range of temperature should i be aware of? I mean, range of temperature i should be running my IGT2. Currently using "Nitro -X" 25 % and thinking of getting 16% soon. Thanks guys
try opening up the hole on the winshield for better air flow to the motor and check your tuning might be too lean on the high speed needle
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 01-12-2009, 07:02 PM   #20
Bullz's Avatar
Thumbs up
Thanks for your comment, MiKaR. I will do exactly what you recomended. Will change to 16% instead of 25%. If i were to upgrade new engine, which engine do u recomended for these heavy weight IGT2? thanks dude.
Bullz is offline   Reply With Quote
Old 01-12-2009, 07:15 PM   #21
Jspeed's Avatar
Once you get the RTR engines running well, set up your suspension up good for your track, get some good tires and you'll be able to win plenty of races against other stock RTR GT cars & even some "mod" cars too.
Jspeed is offline   Reply With Quote
Old 01-12-2009, 07:54 PM   #22
Bullz's Avatar
Thumbs up
Hi Jspeed, thanks for the comment. May i ask what do u mean, "setup your suspension" ? A local racer once told me that the absorber silicon Oil need to be change with difference "grade number"???? He said, front 250 back 400 of silicon oil.The only thing i hop-up is the stabizer for front and back.
Old 01-13-2009, 02:59 AM   #23
Jspeed's Avatar
I would say that what ever thickness of shock oil you try, put the same in all 4 shocks start.
Try to join the IGT proboards, there is a lot of set-up help available there. In this racing game tires, set-up and practice are everything.
Old 01-13-2009, 06:34 AM   #24
Bullz's Avatar
Thumbs up
Thanks for the info Jspeed.
Kyosho Inferno VE UK.hardcore Electric Off-Road 95 08-29-2010 09:22 AM
Kyosho Inferno GT2 737 JEtMech Nitro On-Road 27 01-13-2010 10:08 PM
