Old 01-06-2004, 08:17 AM   #16
Default Re: wd40
Originally posted by FTSPEEDWAY
if you use wd40 you could blow your engine. I had a friend do that to a novamega mcp and it snaped the rod big time. after run oil for me.
If your friend blew his motor it wasn't because of the WD-40.
trey is offline   Reply With Quote
Old 01-06-2004, 08:18 AM   #17
Default Re: tires
Originally posted by r12 schumacher
these are for 1/8 scale dstributed by rbconcepts.
They look like rubber? Have you tried them?
Old 01-06-2004, 08:28 AM   #18
Send a message via AIM to kreidel
Default Re: Re: wd40
Wd40 is not good for engines...machinists and locksmiths use it because it makes a great cutting oil...makes you wonder what is does to your engine.
kreidel is offline   Reply With Quote
Old 01-06-2004, 08:31 AM   #19
Regional Moderator
Darkseid's Avatar
Everyone has a friend, or a friend of a friend, or somebody who has destroyed just about EVERY component in every RC car becasue of something seemingly harmless. I find that its best to only speak of experiences you yourself have actually had. So that way you know all the facts about it. He may be a friend, but you can't follow him home and see what he's doing to his engine there.
I ran a OFNA .15 engine for years using WD-40 as my only afterrun lube. And the thing still has excellent compression. Now I use Hobbico's after run oil. Which as I understand it is the same as every other 'red colored' after run oil.
But like someone said before, if blew a rod or whatever in his engine, he needed more than wd-40 to do it!
TLR 22...Tamiya F104...
Old 01-06-2004, 06:54 PM   #20
WD-40 attacks the surface of metal, so that they can dissolve the rust on surface of metal.
utopian is offline   Reply With Quote
Old 01-06-2004, 07:34 PM   #21
vtl1180ny's Avatar
R/C Tech Charter Subscriber
WD 40 is used because it's great at inhibiting rust and keeping water from sitting on the metal...
vtl1180ny is offline   Reply With Quote
Old 01-06-2004, 07:37 PM   #22
Manticore's Avatar
where is da fish?? here comes your hot topic ! time to use your KY again !
Manticore is offline   Reply With Quote
Old 01-06-2004, 10:55 PM   #23
FTSPEEDWAY
Guest
Posts: n/a
On the wd-40 issue. What happens is if you put wd40 in a motor it will repell the moisture in the air. The only place for the moisture to go is to the bottom of the case. Wd40 does not prevent corrosion and the rod corroded when he started the engine up the rod gave in and snapped. This is why i would not reccomend wd40 in a nitro engine.
Old 01-06-2004, 11:46 PM   #24
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
In KY, we trust.
eddiethefish is offline   Reply With Quote
F.S. Lot of New Nitro Sedan foam tires Stlfc R/C Items: For Sale/Trade 1 07-26-2008 09:53 AM
NITRO TC FOAM TIRES!!! swerv512 R/C Items: For Sale/Trade 2 03-03-2007 03:42 PM
Good Nitro Foam tires. rcfoolz R/C Items: For Sale/Trade 2 11-19-2006 01:37 AM
NIB GQ 1/10th Nitro Foam Tires 37 Shore F/R boom R/C Items: For Sale/Trade 3 07-30-2006 03:29 PM
WTB 30 mm rear jaco nitro 5 star foam tires and .12 turbo 5 port nitro engine & pipe fasthpir40 R/C Items: For Sale/Trade 0 01-24-2005 09:03 AM
