Best Charger To Get >
Best Charger To Get
Best Charger To Get
Old 12-15-2008, 09:24 AM
rias5037's Avatar
Default Best Charger To Get
not sure if this is the right section to ask this, but here it goes:
anyonew know what charger to get that cab charge my 5cell 1100Mah receiver pack and the radio's 8 cell 2600mah batteries as well as my glow starter, a bonus would be something that can also charge gel 12v batterie for my starter box as well.
the charger must be able to run on 220V ac power as well, and preferably charge batteries simultaneously.
ive seen a couple on ebay from china, but not sure if its gona last or would be able to do what i want it to.
heres the item number for the charger ive seen on ebay:
Item number: 360116397647
any advice would be greatly appreciated.
thanks guys
rias5037 is offline
Old 12-15-2008, 09:36 AM
Trader Rating: 4 (83%+)
this is a great deal ...
http://www.horizonhobby.com/Products...ProdID=VNR0657
Roniel_R is offline
Old 12-15-2008, 09:43 AM
rpespo's Avatar
This one does it all plus you can charge 2 batteries at one time.
http://www3.towerhobbies.com/cgi-bin...?&I=LXLCJ6&P=7
rpespo is offline
Old 12-15-2008, 10:02 AM
RC MARKET's Avatar
Orion
ADVANTAGE CHARGER CLUBMAN Li-Po $5x only
Spec:
The Team Orion Clubman LiPo Edition is the brother of the Clubman: it additionally charges LiPo batteries and features the constant voltage charge mode. The LiPo edition charger provides you with all the good features of the Clubman, but adds LiPo and A123 charge capability and constant voltage charge mode. With the LiPo Edition you have one charger for all applications!
Technical Specifications Clubman LiPo
* Charging Mode : Fast, storage, constant, current, constant voltage
* Charging Capability : NiMH & NiCd: 1 to 10 cells, LiPo & A123: 1 to 4 cells
* Charge current : 0.1-6A for NiMH/NiCd (1-6 cells) and LiPo/A123 (1-2 cells) 0.1-4A for NiMH/NiCd (7-10 cells) and LiPo/A123 (3-4cells)
* Discharge Current : 0.1-1A (5W-limit)
* Discharge Cut-off Voltage : 0.9V/cell default for NiMH/NiCd, adjustable 3.2C/cell default for LiPo, adjustable 3V default for A123, adjustable
* Dimensions : 13890x30 mm , 54.335.411.8 in.
* Input Voltage (V) : 10-15 VDC
* Delta Peak, Laser Blue LCD Display, 10 User Profiles, Multi-Protection System
Both chargers come with a complete set of cables and
an instructions manual in english, german, french and
japanese language!
http://rcmarket.com.hk/product_info....oducts_id=5022
RC MARKET is offline
Old 12-15-2008, 10:13 AM
GHETTOTEACHER's Avatar
The Triton 2 is a good charger that can charge gel cells, lipo's (5 cells) and more. Priced around $129.00
As for power, you will need a power supply.
GHETTOTEACHER is offline
Old 12-15-2008, 10:14 AM
Team Kamikaze's Avatar
I agree that the Triton 2 is good, but the new Triton EQ is a better deal, it charges all sorts of batteries and it has a built in Lipo battery balancer for all brands of Lipo including Thunder power, and the best of all is it is AC/DC, no need for a separate power supply! the price is only US$129.99.
Team Kamikaze is offline
Old 12-15-2008, 10:18 AM
rias5037's Avatar
MRC Super Brain 977 Charger
sam, this one looks like it could do the deal, what do you think?
rias5037 is offline
Old 12-15-2008, 10:19 AM
Roelof's Avatar
For normal use (without BP batteries) the Graupner Ultramat 14 is a way to go. It is small and light, it runs on 12/110/220 volt, will charche NiMh/NiCad up to 14 cells and LiPo up to 4 cells
Otherwise I advise a 12 volt charger with a small power supply.
BMI has a small 10A one:
http://www.bmi-models.com/#en/2132_-...ply_10A/6/1710
As charger the current Robbe models with a BID cip works awesome. You can mount a BID chip (3 to 4 dollar) to the battery and when connecting it to the charger it will know which battery it is and adjust the charger to it. The chip is also used as a data logger to show the number of charges and compare the status of the battery with older charge data.
Roelof is offline
Old 12-15-2008, 10:26 AM
Yes the MRC 977 is okay but the Triton EQ is better, for $20.00 more you get a built in Lipo balancer charger. here is a link to it http://www3.towerhobbies.com/cgi-bin...&I=LXVRS6&P=ML yes I do have them in stock!
Old 12-15-2008, 08:44 PM
Damn, I just bought the Triton 2 this summer for my field charger and last week picked up a Team Checkpoint (Ice on steriods). I wish someone would have told me about the "New Triton!!"earlier. The Triton 2 will work fine for me.
Old 12-15-2008, 08:45 PM
It's okay, you can always have a spare charger
Old 12-15-2008, 10:03 PM
Chiefy 707's Avatar
I was in the same boat as you and chose the Venom Pro Charger (VEN0657). It charges pretty much anything and comes with all the adaptors needed to do so. Plus it's AC/DC.
When I 1st pulled it out of the box I wanted to try every adaptor it came with so I ended up charging my old igniter, my receiver pack, my buddy's receiver pack (different plug), my starter box batteries, my buddy's starter box lead acid battery, and the shop's Traxxas Slash. I didn't get to try charging a LiPo but the Venom charger does come with a balancing plug adaptor for 2-6 cells.
Originally I was eyeballing 2 different chargers. A cheap one, Duratrax Onyx 230. And a pricey one, Trinity I-Balance. Then I saw the Venom Pro Charger and was glad I made the purchase.
Other chargers around the same price can do the same but not many chargers come with the adaptors like the Venom does.
Chiefy 707 is offline
Old 12-15-2008, 10:16 PM
revo523's Avatar
I also have the venom pro charger and its a really good charger i can charge everything i have and like someone said it comes with all the plugs to charge anything you need, it also has a software so you can check the temp on your pc when you charging your lipos.
revo523 is offline
Old 12-15-2008, 10:19 PM
CCH1978's Avatar
Trader Rating: 27 (100%+)
get the venom charger
CCH1978 is offline
Old 12-15-2008, 10:32 PM
RC MARKET's Avatar
Orion
$50 only !
