Old 10-14-2003, 02:45 AM   #1
Franky's Avatar
Default Os Cvx12
I have a problem here. i can start it easy. but once the glow warmer is away from the plug, it stops.
could it be the cod rod problem? or i have change another plug, still the case.
Franky is offline   Reply With Quote
Old 10-14-2003, 12:57 PM   #2
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
sounds like a glowplug to me.. or your carb settings are off
2mcgrath is offline   Reply With Quote
Old 10-14-2003, 03:26 PM   #3
Fisher890's Avatar
Sounds like its rich. Have you tried idleing it up or leaning the LS needle?
Fisher890 is offline   Reply With Quote
Old 10-14-2003, 03:41 PM   #4
Franky's Avatar
yes, it was too rich, the bottom of the engine is full of fuel.
well, i lean it to 1.1/4 turn, mixture needle leaner too.
now, it is running ok, the temp is only 80-90. very strange.
Old 10-14-2003, 05:32 PM   #5
Hi Franky,
When you are tuning your OS are you winding the mixture screws in then counting the turns out?
If so incorrect,they need to be level with the screw holders then you wind them in.
My favourite hopups are,cen head,A5 os plug and flowing the manifold+ internal work.
xray vision is offline   Reply With Quote
Old 10-14-2003, 06:13 PM   #6
Franky's Avatar
thanks vision,
the main needle is 1.1/4 turns,
the mixture needle is the factory setting, i lean it a little bit.
thank you for advice, it works fine now.
Old 10-16-2003, 12:04 AM   #7
Send a message via ICQ to littlewing
hey can neone tell me how fast it an O.S 12CV engine ??
littlewing is offline   Reply With Quote
Old 10-16-2003, 01:37 PM   #8
Omar's Avatar
it depends on your car or truck, two speed or no two speed and gearing, these are all factors that will effect your speed.
Omar is offline   Reply With Quote
Old 10-17-2003, 12:30 AM   #9
oh yeah ..its an HPI RS4 3 and no 2 speed !!!!!!
Old 10-17-2003, 12:32 AM   #10
tIANcI's Avatar
littlewing - NOT fast enough ... hehehe ... I love the Italian 5 ports.
tIANcI is offline   Reply With Quote
Old 10-17-2003, 12:39 AM   #11
Maybe so but rear and side exhaust motor's are two different things......
Nice feeling when you run a cvx against a cvr and other side exhaust tourer's and pass them on the main straight......
Old 10-18-2003, 09:24 AM   #12
then is the O.S 12CV faster that a GS 15 in the v-one-s ?
Old 10-19-2003, 09:16 PM   #13
i would say in the rtr rs4 3 with that engine you will be running high 30mph's or low 40mph's
Old 10-20-2003, 01:13 AM   #14
oh okok thx a lot !!!!!!
