Old 10-13-2003, 05:37 PM   #1
Thunder racer's Avatar
Default Engin Sealing
Hey guys and girls
Ive got a Problem with my NOVA JP its leeking fuel from the bottom of the carb and there is allways dirt and stuff stuck to the block because of the fuel. CAn you help me out on what i should use to seal it with. Or should i just pull the engin down and leave it in petrol over night so that it gets alll clean.
THANKS
Thunder racer is offline   Reply With Quote
Old 10-13-2003, 09:34 PM   #2
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
have you checked the oring on the carb????also if it is good you might wanna try a fine bead of high temp silicone on the oring that will seal it up...just use a tooth pic or something to apply the silicone and dont put to much...
2mcgrath is offline   Reply With Quote
Old 10-13-2003, 11:41 PM   #3
Are you sure it's not leaking from the front bearing? U might just have a case of the standard JP front bearing leak.
Dexter is offline   Reply With Quote
Old 10-14-2003, 12:43 AM   #4
i dont know now maybe. How do i tell and can i buy new bearings how do i get the old bearing OUT.
THANKS
it is all alround the bottom of the carb but.
Old 10-15-2003, 01:58 AM   #5
I don't think you can do anything about it! Even when i have changed front bearings it still seems to pump it out by the litre. The best way i think to tell if it is leaking out the front bearing would be to look parrallel with the engine's flywheel and see if there is any fuel there. For example with my EVO i have fuel all on the radio plate support. If u do want to get them out i think heating up the crankcase with a hair dryer or heat gun would do the trick.
Old 10-15-2003, 02:45 AM   #6
yer i think i will just leave it im planing on buy a new nova 5port anyway.
THANKS ANYWAY!!!!
ae .15 engin question! aoizip Electric Off-Road 6 07-13-2004 10:37 PM
Engin Break-In? TB01 Nitro On-Road 22 11-06-2003 10:01 PM
Engin Madam Lee Malaysian R/C Racers 12 09-02-2003 11:00 PM
can't get the carb off my engin NTC3 Racer Nitro On-Road 1 06-21-2003 07:46 PM
break in an engin bob's tc3 Electric Off-Road 8 01-11-2003 10:02 AM
