Old 10-12-2003, 10:31 PM   #1
thefuzzclub's Avatar
Default manifold rule of thumb
confused on this, what's the performance if you use longer manifold vs shorter manifold?
thefuzzclub is offline   Reply With Quote
Old 10-12-2003, 10:42 PM   #2
tIANcI's Avatar
If you increase the length in between the manifold and pipe, the engine will get better low rpm power(more torque) but you will loose high rpm power(less rpm at full speed).
If you decrease the length in between the manifold and pipe, the engine will get better high rpm power(more rpm at full speed) but you will loose low rpm power(less torque).
Hence ... size does matter!!!
tIANcI is offline   Reply With Quote
Old 10-12-2003, 10:51 PM   #3
interesting. thanks for the reply bro.
Old 10-12-2003, 11:07 PM   #4
icon's Avatar
Send a message via AIM to icon
-edited- yep i'm wrong, cuz my memory is vague after coming back from a japanese buffet (with a good heineken, some plum wine, and a good amount of sake ).
<<hope i'm typing this correctly.>>
manifold length and space between the manifold and the pipe are two different things. pretty sure the info before me is correct so kudos to you :-).
icon is offline   Reply With Quote
Old 10-12-2003, 11:32 PM   #5
The Sleeper's Avatar
Icon, I believe you have that backwards,,
short manifolds = higher rpms
long manifolds = more torgue
You can increase your top speed by shortening your manifold. You do this by cutting a small section off the end of the manifold. Don't cut more than 1/8 inch at a time and check for any performance gain after each cut. Use a stopwatch to see how long it takes your car to go at least 100 feet at wide open throttle (make sure your engine temp isn't too high). If you see a increase in speed then you can cut another 1/8 inch off the manifold and test again. Continue cutting the manifold until there is no increase in speed.
The Sleeper is offline   Reply With Quote
Old 10-12-2003, 11:36 PM   #6
icon's Avatar
ah, thank you .
Old 10-12-2003, 11:51 PM   #7
Old Skool's Avatar
Of course, in-line exhaust systems would be a right bitch to perform these mods on, lol.
Old Skool is offline   Reply With Quote
Old 10-12-2003, 11:56 PM   #8
icon's Avatar
LMAO. hehe, thats what my last car used so my manifold knowledge is sketchy.
Old 10-13-2003, 12:08 AM   #9
i know this is not the ntc3 thread but just to share the pipe i'm using is dynamite inline pipe with a long manilfold design, my engine is novarossi s5 and this is bolted in my ntc3. i'm not sure if
the manifold length has a great effect on its torque or i have to change my pinion gears combo.
Old 10-13-2003, 01:06 AM   #10
I was going to say that but just got tired of typing such a long post
Old 10-16-2003, 10:36 AM   #11
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
i love short manifolds because of the amount of top end rev. The low end doens't hurt that much if you run a centax, just tighten it down. (engage later)
mtx3racer is offline   Reply With Quote
Old 10-16-2003, 11:10 AM   #12
Shhhhhhhh!!!!!!! You're giving away one of the best kept secrets...
tekrsq is offline   Reply With Quote
Old 10-16-2003, 11:36 AM   #13
Corse-R's Avatar
Nothing more hassling that asking in your machine shop to do do some aluminium collars for sliding between the pipe and the manifold. More clean, more crash resistant and more 'repeatable'.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-16-2003, 12:47 PM   #14
Your right, i'll hush down
Charge and discharge rule of thumb? HeltonPrecision Radio and Electronics 1 01-21-2008 03:20 PM
WTB Jump/Thumb USB Drive jg6009 Other Items: For Sale/Trade or Wanted to Buy 2 05-19-2005 06:36 PM
manifold rule of thumb thefuzzclub Nitro On-Road 1 03-04-2005 09:49 PM
Jayhaya = thumb up Diva Buyer/Seller dispute and Feedback discussion forum 0 11-21-2002 09:39 PM
Trade: New NTC3 Side Exhaust & Manifold for your Brand New Rear Exhaust & Manifold fish66 R/C Items: For Sale/Trade 1 07-30-2002 04:54 PM
