Old 08-28-2002, 12:01 AM   #151
rcruv's Avatar
Steve > Do you have Kawahara 27T pinion for NTC3 in stock?
Thank you.
rcruv is offline   Reply With Quote
Old 08-28-2002, 08:31 AM   #152
Registered User
Send a message via AIM to bbntc3
Steve: any idea when the Zac project 21/12 nova head will be in stock? Thanks: BB
bbntc3 is offline   Reply With Quote
Old 08-28-2002, 08:47 AM   #153
SpeedTech's Avatar
bbntc3, rcruv,
We are suppose to receive a Kawahara shipment this week, but I know our supplier is still out of stock on the 27T pinion. We might get some engine heads.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 08-28-2002, 08:53 AM   #154
Regional Moderator
racer rich's Avatar
Steve-
Will the "PID K-419 Kawahara Aluminum Brake Bracket and Side Bracket" be in the Kawahara shipment? I have been looking to get that for a while now.
Thanks,
Rich
racer rich is offline   Reply With Quote
Old 08-28-2002, 09:19 AM   #155
Registered User
Thanks Steve!!
Old 08-28-2002, 10:10 PM   #156
SpeedTech's Avatar
racer rich,
Most likely I have a feeling it won't be, but we stock a similar unit from integy now. I will be adding those parts to the website tomorrow.
bbntc3,
no problem
Also, new from Speed Tech R/C is the personal lap counting stand. this is a much better unit than the Orion one, for a lot less. Check it out on our website
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 08-29-2002, 03:47 PM   #157
SpeedTech's Avatar
Hi Guys,
We just got more Kawahara NTC3 Micro Centax clutch in stock. They are available on our website right now. This centax clutch uses a small flywheel and it comes with a set of low CG engine mounts to go with it.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 08-29-2002, 04:48 PM   #158
Steve,
Sent you an e-mail a few days ago, but no response. I need the aluminum 2nd gear housing for the Kawahara MTX-2 2 speed tranny. The bearing in mine has locked up.
tekrsq is offline   Reply With Quote
Old 08-29-2002, 05:24 PM   #159
SpeedTech's Avatar
tekrsq,
Sorry about that, you got mail!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 08-30-2002, 09:09 AM   #160
SpeedTech's Avatar
Hi Guys,
We got more hop-ups back in stock:
* Proline Crowd pleazer body (200mm)
* Kawahara NTC3 Centax Clutch Set
* Zac Project large .12 engine heads
* Mugen Fast Tire Foam tires
Also, check out our new personal lap counting stand. This unit have been track tested with excellent feedback, and look for a review in upcoming issues of Xtreme R/C Magazine.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 08-31-2002, 09:25 AM   #161
Registered User
Hey Steve I ordered the Zac 12 head for rossi based 12's and you are out of stock on the gray can you change my order to the purple one in stock? My order # is 4199 Thanks BB
Old 08-31-2002, 10:11 AM   #162
rcruv's Avatar
Steve > What foam tires do you recommend for NTC3 with Baker setup?
I will be racing either Revelation or Crystal park.
Thank you in advance.
Old 08-31-2002, 03:49 PM   #163
SpeedTech's Avatar
BB,
No problem, I'll change the color to purple.
rcruv,
A lot of guys are going softer on their NTC3 as far as foam tires. Lately we've been moving a lot of 37 shore rears and 40 shore fronts, and these are for racers that race at Crystal Park on a regular basis.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 08-31-2002, 09:21 PM   #164
rcruv's Avatar
Steve > Thanks a lot. Do you have part number for those?
I would like to order one set of front and one set of rear.
Originally posted by SpeedTech
BB,
rcruv,
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 09-01-2002, 09:13 AM   #165
SpeedTech's Avatar
rcruv,
They are from Mugen racing (they are called Fast Tires) and we have them on our website under the Mugen Foam tire section. The front 26mm are part number FVX4x (and you select the shore rating from the menu) and the rear 26mm are part numbers FVX5x (select shore rating from the option menu) and finally the 30mm rears are part number FVX6x (shore rating from the option menu)
Steve Wang
Speed Tech R/C
www.speedtechrc.com
What's new @ Speed Tech R/C SpeedTech Electric On-Road 3209 01-19-2006 11:00 PM
What's new at Speed Tech R/C SpeedTech Racing Forum 30 02-10-2003 01:58 PM
What's new at Speed Tech R/C SpeedTech Electric On-Road 80 04-15-2002 11:43 AM
