Old 11-30-2008, 08:59 AM   #1
Default Gear compatability question for Kyosho V1RRRRRRRR series
Hi guys,
I got a V1R and I am finding it hard to get pinions and spurs for it now. It uses the 1.0 pitch gears(pinion and spurs). My question is has anyone tried putting on the new 0.8 pitch gears(pinion and spurs) from the latest V1RRR onto the V1R drive train(V1R clutch bell, spur gear shaft). Thanks to all the gurus out there.
Cheers
aleris is offline   Reply With Quote
Old 11-30-2008, 01:09 PM   #2
carkillaii's Avatar
Yes It will work , i have a v1r dont run it , i run my rrr but the 2speed shaft is off just a lilbit if your going to use the evo shaft it might work ,if you dont need to change the shaft the .08 gears will work fine the mid shaft has not changed
carkillaii is offline   Reply With Quote
Old 12-01-2008, 01:33 AM   #3
Thanks for the reply. I just wanna check if I got you right.
You're saying that I could use the 0.8 spur gears on my V1R spur gear shaft but it will be a little bit off. And to get it right I will need to also change spur gear shaft to a V1RRR spur gear shaft?
Old 12-01-2008, 01:36 AM   #4
carkillaii's Avatar
no keep the vir shaft just change the gears.
Old 12-01-2008, 03:24 AM   #5
Thanks for clarifying. I can now go out and get a whole setup or spurs and pinions
