Old 11-28-2008, 01:05 PM   #1
TRYMY4.0's Avatar
Trader Rating: 10 (86%+)
Send a message via AIM to TRYMY4.0
Default ◄I've tried everything...tuning help please►
I just recently bought a new HPI RS4 EVO 3+ and i've had problems since day one with it. So far, this is my setup, 3.0 engine, MC11 plug, HPI tuned exhaust, Byron 20% fuel. I've messed with everything to get this thing to run right and it wont. If I am able to give it top end, low end is sh*t and dies. If I give it low end, high end bogs and dies. I had to use a new fuel line b/c I routed the 1st one wrong and got chewed up. The new one is the same size but maybe a tad longer. Would the length cause a problem?
Typically, I can half throttle it everywhere just fine. Full throttle at 25+mph it'll bog out then die (if I don't let go of the throttle). It'll push a bunch of smoke then none when it dies. At idle it will sound like there is too much fuel then bog out or if I am able to get it to move it'll bog out and die.
This is really messing with me b/c I have a firestorm (same engine) and it runs great.
Any and all help would be FANTASTIC.
-Ant.
POOWWWWWWAAAAAAAAA SLLLLIIIIIDDDDDEEEEE!!!!
TRYMY4.0 is offline   Reply With Quote
Old 11-28-2008, 01:13 PM   #2
Have you checked to see if your gas tank is air tight?
Mugen USA-FX Hobbies-Airtronics
TONY CLARK
STRICTLYSERPENT is offline   Reply With Quote
Old 11-28-2008, 01:41 PM   #3
TRYMY4.0's Avatar
No I have not. I believe it is. How would I check? run the hose so it doesnt leak and tip it over?
-Ant.
Old 11-28-2008, 01:44 PM   #4
Trader Rating: 4 (83%+)
you should start from factory setting and tune from there,normally those engines like to run on the lean side
Roniel_R is offline   Reply With Quote
Old 11-28-2008, 01:50 PM   #5
TRYMY4.0's Avatar
The high speed needle is at factory and still bogs/dies at the top end. There is no factory setting guide for the low speed needle. I can make it flush (which is prob what it is) and I think I have made it flush and still had issues.
-Ant.
Old 11-28-2008, 03:53 PM   #6
GHETTOTEACHER's Avatar
I would change that plug. It sounds like to me that the engine is fireing late. The temps have changed so it's cooler outside. Small blocks love to run on the hotter side. Install a hot plug and retune. I don't know McCoy plug numbers, but OS. 3 or a Novarossi 6 would heat things up.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 11-28-2008, 04:08 PM   #7
TRYMY4.0's Avatar
^thanks. I was running an O.S. 3 in my firestorm and it ran fine. I've also got 3 O'donnel 77 plugs. They are med/hot. I will try one of them tomorrow to see if it works better.
I agree with the firing, when driving it sounds like it is misfiring. (i work at a auto repair shop) I will agree to it being cooler out, but today in Georgia it was about 60-70.
-Ant.
Old 11-28-2008, 10:31 PM   #8
NiTrO BoOsTeR's Avatar
dude dont use a OS A3 they are for running in an engine, use the OS no.8 or a A5, you wont a plug that is med for basicly anywhere its a good place to get started.
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 11-29-2008, 05:42 AM   #9
s10dude's Avatar
sounds like gast tank seal..not enough pressure top end to push enough fuel
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 11-29-2008, 06:52 AM   #10
TRYMY4.0's Avatar
I filled the tank up and set it upside down for an hour and it didn't leak. I guess I could always just order another one just in case.
-Ant.
Old 11-29-2008, 07:44 AM   #11
wizby's Avatar
Try running a wire through the presure nipple on the pipe. Never know if thats plugged up from the factory. Low speed needle orings could be leaking. Is there any wettness around the head? Or exhaust system?
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 11-29-2008, 08:32 AM   #12
CurveTracer's Avatar
Default Testing Fuel Tank Integrity
-Ant.
Laying the car upside down may not detect a fuel system leak.
Here is a better method: remove the fuel tank, with its carburetor line and pressure line. Pinch off the exhaust pipe pressure line, blow air into the fuel line and pinch it off also. Now you have a pressurized fuel system. Submerge the entire assembly into a container of water. Look for air bubbles escaping arround the fuel tank, tank lid, pressure, or fuel line.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 11-29-2008, 11:36 AM   #13
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
What are you tuning with? Just one needle or both?
Did you read the directions on tuning and you want to tune it when its warmed up and hot. Also pull your plug, try another one.
Beyond that for sake of giving you something to go with. Im not sure how familiar your with tuning.
But I would run the car around...tune the top end. Make sure its smoking and not bogging out and running right. Then bring it in , let it idle for a few seconds , then give it gas....what does it do...act boggy or act real responsive.
Go from there , if its boggy , just lean the low end until its a good mixture of power , smoke and responsiveness. Then take it back out and retune the top-end again if need be.
Artificial-I is offline   Reply With Quote
Old 11-29-2008, 01:23 PM   #14
revo523's Avatar
Put everything back to factory settings let the car warm up and start with your highend needle once its where you want it then move to the lowend needle. sounds to me like a engine thats running fat!
revo523 is offline   Reply With Quote
Old 11-29-2008, 06:07 PM   #15
TRYMY4.0's Avatar
I have done all that. I returned the HSN to factory and it bogs and cuts off. Could it be the engine?
Ok, thanks a lot. I am going to do that RIGHT NOW!
I know, it seems like too much fuel is getting in an locks up but when I lean it out....same thing.
-Ant.
