Old 02-15-2012, 06:07 AM   #1756
Bishop's Avatar
Originally Posted by TomB View Post
could you post this for those who do not have access to facebook. thanks
Give me a min, just doing a copy and upload to my own site so I can post some direct pics in here...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 02-15-2012, 06:08 AM   #1757
Bishop's Avatar
QRCCRA
www.qrccra.org.au
Old 02-15-2012, 09:00 AM   #1758
Faiq-X4's Avatar
hi all.. same as what i'm doing with my 4R.. no stripping issues
MTX-6
M11-X
Novarossi
JBRCC
Faiq-X4 is offline   Reply With Quote
Old 02-15-2012, 09:18 PM   #1759
CanyonCarverR1's Avatar
Default New Kit
Any word as to when the new kit(T2002) will be out?
CanyonCarverR1 is offline   Reply With Quote
Old 02-15-2012, 10:40 PM   #1760
Bishop's Avatar
It's actually out already, Japan has had stock for a couple of weeks, but my guess is other countries importers won't buy stock until they run out the old model.
I still can't figure out the rear upper bulkhead changes for the new parts, can't see anything wrong with the old/original.
QRCCRA
www.qrccra.org.au
Old 02-15-2012, 11:36 PM   #1761
Default mtx5
at least when you pulled 4r apart you would always find some thing wrong played with baileys car to day dam savox is buggerd all ready at least ace lasted 4 years
greg.dawn is offline   Reply With Quote
Old 02-15-2012, 11:59 PM   #1762
Bishop's Avatar
What's busted Greg?, the Savox are rebuildable to a point, replacement case is about $6, replacement gearset is $15-$25 depending on model.
Savox were never going to have the durability of the Ace, in part cause they are not built like the Ace, but they weight a lot less, and cost half the price.
QRCCRA
www.qrccra.org.au
Old 02-16-2012, 12:29 AM   #1763
shanwright's Avatar
Trader Rating: 25 (100%+)
Thumbs up I have a few spares servos if you need one quick!
I also have one with motor thats shot so the gears are good you could have them if you need.
Steve H
shanwright is offline   Reply With Quote
Old 02-16-2012, 02:59 AM   #1764
Default savox
ex/brake shakes all over the place if you stop it in wrong place it stays there no chep if onley 3 mounts old ace were over4 years old
Old 02-16-2012, 03:35 AM   #1765
Greg usually throttle servos fail when the endpoints are set incorrectly. ask someone at the track to help you set it up mate.
TomB is offline   Reply With Quote
Old 02-16-2012, 04:16 AM   #1766
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
The rear diff uses a different plastic (bigger size) hence the new bulkheads and carbon brace (to allow the diff to clear).
Michael_T is offline   Reply With Quote
Old 02-16-2012, 10:54 AM   #1767
Bishop's Avatar
Speaking of diffs, I just finished the postmortem on my rear diff, no destructive failure like a few posted with pins chewing out the backs of the larger gears, the smaller gears in mine simply wore out...
Interesting observation while doing the rebuild, plastic gears make a 27 gram diff, replaced with metal it's now 38 grams, quite a weight change to the cars driveline, I'm guessing if your out for every last scrap of power, you'd run the plastics and rebuild a few times during a major meet?.
And I have to say, all the hype of other brands, but every time I work on my five, I'm reminded why I still think it's the best car out there, and don't regret buying it for a second, cause it's just so easy to work on...
QRCCRA
www.qrccra.org.au
Old 02-16-2012, 03:04 PM   #1768
djiewie's Avatar
Could it be that the gears were running a bit thight. i have used the plastic gears (from cap)in my diffs also but noticed the pin was eating away in the slot from the larger gears. Replaced only those and ran the whole season without replacing them. Then its not that much weight more. Maybe you can try it. (i run the NT1 though, also a good car)
nice tutorial on the clutch by the way.
djiewie is offline   Reply With Quote
Old 02-16-2012, 03:09 PM   #1769
Default servos
i have no prob with end point adj as it bends chassis if to much but thanks tom
Old 02-16-2012, 03:15 PM   #1770
Roelof's Avatar
Send a message via ICQ to Roelof
Any experienced racer should know this without a tutorial.....
What I am missing is that the endplay in the clutch can be a disturbing factor to line up the gears. you have to pull the clutchbell from the flywheel to be sure to get the right position when the clutch is engadged.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
