Old 10-05-2003, 04:12 PM   #1
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
Default engine wont start
i have a question here i have a hpi rs4 3 ss with the 12r ss engine..i was running the other night runned about 4 tanks or so out and runned out of fuel again..so i pulled it in to refuel and did so but after refueling the car would not start back..so i just thought it may be the plug so i drained the fuel out of the tank and quit for the night...and went back out today to run with some friends the car still would not crank..i changed to a new plug still no luck..when i pulled the glow starter off i noticed the head on the engine was loose..so i retightened the head and still no luck...the car is tuned properly..could it be a head gasket blowed from where the head was loose????if so how can i tell or does anybody have any ideas what it may be as we are gonna to go running again tonight...please help asap
2mcgrath is offline   Reply With Quote
Old 10-05-2003, 06:20 PM   #2
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
it might be leaking somewhere, check your carb and gaskets.
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 10-06-2003, 03:08 AM   #3
We shared a same problem.. I tot I just the only one who experienced it. have U check your head gasket?
shah285 is offline   Reply With Quote
Old 10-06-2003, 10:21 AM   #4
i finanlly got it to crank yesss...and got to run last night...i took the head off and cleaned the head and gasket up...put it back together and still wouldnt crank...so i took the plug from another car just to try again and it cranked...but whats funny is the plug that was in my car will crank other cars weird...i even tried a brand new plug before taking the head off with no results
ENGINE WONT START??? Roadrash730 Onroad Nitro Engine Zone 3 01-28-2008 10:47 AM
Engine wont start help! Hpimichael Nitro On-Road 5 03-01-2007 11:03 PM
Engine wont start...need help !! thank you alexlai50 Nitro On-Road 8 11-11-2005 09:18 AM
trx pro. 15 engine wont start, need help... 72skylinegs Onroad Nitro Engine Zone 2 10-09-2005 01:44 AM
Engine wont start dvargas Nitro On-Road 1 04-26-2003 11:17 PM
