Old 11-09-2008, 03:51 PM   #1
Questions?? Need help with differential Setups
Hello all...
Was hoping someone could tell me the theory behind the the different weight oil in the front and rear differentials of a 1/10 sedan.
I have a GS Vision Pro kit which I'm rebuilding and although the manual suggest 7000 wt in the front, and 4000 wt in the rear. What does this do?
I was wondering how various weights front and back would affect the car? Also what does same oil weight in front and back do? Does it give car a truer 4wd?
Any insight would be greatly appreciated.
Car
GS Vision Pro
Radio
JRRacing XR3
Engine
Siro Outlaw .12
Kyo83 is offline   Reply With Quote
Old 11-10-2008, 06:28 AM   #2
s10dude's Avatar
the heavy the weight oil makes both wheels pull more at the same rate.
lighter oil allows the wheels to move at different rates
heavy oil upfront makes car handle like it has a spool in it i.e.100,000w
usaully 10 0r 20,000 in rear and 30,000 or higher in front depending on your driving style and preference
thicker oil also makes the car more stable under braking
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 11-11-2008, 12:06 AM   #3
Thanks Chief!
Old 11-11-2008, 12:28 AM   #4
grub's Avatar
hope this helps
EFFECTS OF FRONT GEAR DIFFERENTIAL ADJUSTMENT
Lighter Front Differential (thinner oil)
• Decreases understeer
• Decreases stability under braking and acceleration
• Increases chance of traction roll
Heavier Front Differential(thicker oil)
• Increases understeer
• Increases stability under braking and acceleration
• Reduces chance of traction roll
EFFECTS OF REAR GEAR DIFFERENTIAL ADJUSTMENT
Lighter Rear Differential (thinner oil)
• Decreases on-throttle steering
• Less acceleration if the grip is there
• Less predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• Less on-throttle oversteer (snap-oversteer)
• Less turn-in understeer
• Less stable under braking
Heavier Rear Differential (thicker oil)
• Increases on-throttle steering
• Better acceleration if the grip is there
• More predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• More on-throttle oversteer (snap-oversteer)
• More turn-in understeer
• More stable under braking
TRACTION CONSIDERATIONS:
* The higher the traction, the lighter the diff oil up front, and the heavier at the rear.
* The lesser the traction, the heavier the diff oil up front, and the lighter at the rear.
all the best grub
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13773 12-12-2017 11:19 AM
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3600 11-01-2017 07:19 AM
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 07:34 AM
Faster corner speed like pro smash123 Electric On-Road 413 08-17-2011 03:21 PM
IMPORTANT: New Product Arrival Alert! (August 2008) rcmart rcMart.com Mega Online R/C Marketplace 106 12-11-2008 10:52 PM
How to drive a one-way? RC_Woody Electric On-Road 29 03-17-2006 02:28 AM
