Old 10-01-2003, 06:35 PM   #1
Default ACC P/S and conrod
Hiya,
Have anybody try an ACC Piston/liner and conrod in a EVO5 MS or a RBC5.....will there be any benefits fron this mod...any info from people who tried it
xtreme888 is offline   Reply With Quote
Old 10-01-2003, 06:55 PM   #2
EdwardN's Avatar
Default Re: ACC P/S and conrod
Originally posted by xtreme888
Hiya,
Did you mean AAC-Aluminnium piston, aluminum sleeve and chrome plating or something new come up?
I personaly defenetly preferd to have AAC then ABC. I use them on the past and AAC can't be compare to ABC, much better, regarding the engine brand. Just needs to be done right way.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 10-01-2003, 06:59 PM   #3
Topgun 777,
Sorry AAC not ACC!!
Would be grateful if you can tell me the benefits, and do it fit in EVO5MS or RBC5.....
Old 10-01-2003, 07:04 PM   #4
EdwardN's Avatar
Topgun 777,
Sorry AAC not ACC!!
Aluminium sleeve have better (more stable) thermo expantion, it has much closer to crancase metall thermoexpantion koeficient, so it won't be loose in case, it has better thermo exchanging. But it more difficult to handle-small mistake in handeling will ruin it (easy to make ellips even in small drop, while you push it down to case-if not aligned right initialy-will ruined too)
Which one you are talking about supose to fit in EVO or RBC5?
Old 10-01-2003, 07:09 PM   #5
Top Gun 777,
Got the Novamega EVO5 MS and Rody RB C5 onroad. Which of these two will benefit the most, and the most easier to fit in without too much mods...
p.s you got pm as well
Old 10-01-2003, 07:13 PM   #6
EdwardN's Avatar
Top Gun 777,
I think both of them will benefit the same, just I belive the pin on other side for RB, easy to adapt.
btw, no PM come yet.
Old 10-01-2003, 07:24 PM   #7
Top Gun 777,
Your pm box was full!!! Hence sent you a email instead.
Old 10-02-2003, 08:38 AM   #8
EdwardN's Avatar
Top Gun 777,
My PM box is Ok now. I will check my e-mails.
Old 10-02-2003, 02:26 PM   #9
Francis M.'s Avatar
i have talked to a few experienced engine
modifiers and they all pretty much told me
that the aluminum sleeve is better because
it expands at the same rate as the aluminum
piston. so they can get closer tolarence from
when the engine is cold to when it warms up.
as far as aac sleeve and pistons. the only
one ive heard of is from sirio.
On another note has anyone tried the
megatech iridium glow plugs on sedan
application. If so whats the pros and cons
I know most spark plug manufacturers are
going to this for racing application in full scale
racing.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-02-2003, 03:59 PM   #10
EdwardN's Avatar
racing.
I have Russian made glow plugs with 80 % platinum and 20 % iridium-do you want to try?
Old 10-02-2003, 08:51 PM   #11
sausage_link's Avatar
Send a message via ICQ to sausage_link
The OS #8 plug has platinum coil...
sausage_link is offline   Reply With Quote
how often to change a conrod MaDaGAS CAR Onroad Nitro Engine Zone 21 02-11-2007 04:17 PM
OS .21 conrod no4hitter R/C Items: Wanted to Buy 3 06-17-2006 02:37 AM
OS VZ-R/VZ-B Conrod and Nova P5 Conrod rod_b R/C Items: For Sale/Trade 2 03-21-2006 06:58 PM
conrod for rb x12 CHUCKMANDO R/C Items: Wanted to Buy 2 05-20-2005 05:32 PM
JP conrod manokgt4 R/C Items: Wanted to Buy 0 01-12-2003 10:12 PM
