Old 11-08-2008, 03:44 PM   #1
dvu
Default Full throttle running
Forgive my ignorance, but I'm still trying to learn nitro cars. As a follow-up to a previous post. I can be running at half throttle just fine, but when I mive to full throttle the engine dies. I've changed out the glow plug and same thing. My thought is that it would have to deal with the amount of fuel getting to the chamber, whether it be too much or too little. In which case I should be toying with the high speed needle. What's wrong with my train of thought.
If it's the clutch setting, how come it runs at medium throttle fine, but when I lay it to it the engine dies.
Thanks again, Duc
dvu is offline   Reply With Quote
Old 11-08-2008, 04:06 PM   #2
s10dude's Avatar
sounds like the high needle is way to lean..........
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 11-08-2008, 05:26 PM   #3
dvu
How can I tellif my high speed needle is too rich or too lean?
Old 11-08-2008, 06:00 PM   #4
Team Kamikaze's Avatar
Too rich then the engine will be blubbering with plenty of smoke and raw fuel coming out of the exhaust and slow when accelerating out of corners.
Too lean then the engine will have very little or no smoke from the exhaust when accelerating out of the corners and runs really hot/overheat.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-08-2008, 06:04 PM   #5
dvu
That makes sense. So do you think my problem sounds like it's in the high speed needle setting?
Old 11-08-2008, 06:10 PM   #6
Yes definitely, how does it react when you go full throttle when the car is not touching the ground? does it accelerate quickly with a very high pitch sound? or does it kind of sputter through out?
Old 11-08-2008, 06:50 PM   #7
wizby's Avatar
When in doubt RICHEN. If you dont richen enough to find the slower responce /not clearing out you never know where your at.
wizby is offline   Reply With Quote
Old 11-08-2008, 07:46 PM   #8
dvu
9/10 when I go full throttle off the ground it has a high piitch o/w seems to run just fine. It will slowly rev with a high pitch from 1/2 throttle to 3/4 throttle and then just die out if I go beyond 3/4 throttle.
Thanks for the help, Duc
Old 11-08-2008, 08:23 PM   #9
As Wizby recommended, if in doubt richen the top, I would richen (counter clockwise) it for 1/4 of a turn and see if it improves, if it does then you know it is too lean, also make sure your pressure line is in good condition, if in doubt replace it with a new pressure line, I have experience that when it gets old it does collapse and restricts pressure going into the tank thus giving acceleration problems.
Old 11-08-2008, 08:33 PM   #10
Genesis's Avatar
Check your fuel tubing, pipe seals and gas tank. For what I gather you probably are not creating presure in the tank.
Depending on the car. Some people tighten the screw or nuts too tight and crack the seam of the tank.
Hope this helps
Genesis Motors - Genesis "Killer Voltz" - Brooklyn Hobbies - JNR Graphics - RB Products - Novak - Losi - JACO - KO Propo - Mugen - VISA, MC and CASH. Decal quote email [email protected]
Genesis is offline   Reply With Quote
Old 11-08-2008, 09:26 PM   #11
dvu
I think I've got it. Thanks for all the help.
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 07:19 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
4 Cell Sedan Racing AdrianM Electric On-Road 484 02-25-2005 06:47 AM
One-way HK Racing Joe Electric On-Road 36 01-28-2005 08:55 AM
Burned Out 2 Throttle Servos....Any Ideas?? tunerjetta29 Nitro On-Road 9 01-12-2005 07:31 PM
