Old 03-29-2009, 05:05 AM   #376
Sp Racer's Avatar
Originally Posted by Sp Racer View Post
OMG
Brendan is taking some pics.....
I used a couple of old radio plates that had the rear holes broken near the grab handle.....just trimmed off the right corner with a dremel and flipped it over - you can see the shape
We wrap a piece of bicycle inner tube around the whole lot to tidy it all up....also, if you look closely you'll see we've moved the throttle servo back a little to give some more space - really easy mod
Team Magic G4 + EVO-dscn0961.jpg   Team Magic G4 + EVO-dscn0960.jpg   Team Magic G4 + EVO-dscn0966.jpg   Team Magic G4 + EVO-dscn0970.jpg   Team Magic G4 + EVO-dscn0971.jpg
Sp Racer is offline   Reply With Quote
Old 03-29-2009, 05:12 AM   #377
Sp Racer's Avatar
more pics
Old 03-29-2009, 07:17 AM   #378
keavze's Avatar
mine is quite similar to SP's but in a different way.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-29-2009, 07:20 PM   #379
Chiefy 707's Avatar
Took a few videos today at the track with a $50 digital camcorder I just got at Walmart...
+ YouTube Video
+ YouTube Video
+ YouTube Video
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 03-30-2009, 01:49 AM   #380
Chiefy 707's Avatar
Been meaning to ask if anyone has my problem with the carb not fully returning to idle. Should I have a little bend here and there on my throttle rod?
Old 03-30-2009, 02:19 AM   #381
keavze's Avatar
should be yr spring tension on the throttle rod not enough...give it abit more tension and see how it goes.
Old 03-30-2009, 05:57 AM   #382
Bundy_Bear's Avatar
more pics
Hi Luis
Thank you for posting those pictures... One question, did you have to move the swivel arm on top of the radio tray? I got the impression it was left alone, but i thought i better check!
How long till the NSW titles?
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 03-30-2009, 06:59 AM   #383
NitroWD's Avatar
Originally Posted by Bundy_Bear View Post
Hi Luis
from the pics i think he shorten the 'link' between the servo horn and the swivel arm without moving the swivel arm back.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 03-30-2009, 07:05 AM   #384
NitroWD's Avatar
from the videos it seems that yr gearing is a bit too tall.
or maybe you didn't really 'race' it.
Old 03-30-2009, 11:49 AM   #385
Chiefy 707's Avatar
Nah I was too scared. My camcorder was scotchtaped to my center body post with no body on.
Old 03-30-2009, 02:41 PM   #386
Sp Racer's Avatar
Hi Luis
Swivel arm is untouched, just a shorter link from the throttle servo.
We leave for NSW next Wednesday, so a little over a week
Styles - no word yet from Zauber
Old 03-30-2009, 03:59 PM   #387
Bundy_Bear's Avatar
Thanks for clearing that up... I will look closely at changing this tonight.
MissMooRC Racing
Old 03-31-2009, 05:36 PM   #388
Great Video!!!
Now that we got our electric "road trips" out of the way we are hoping to spend some quality time at VRC.
We had the same results turning the receiver box around. What we are working on now is getting some custom LiPos made for the car. With the "spaceship" fuel tank there is not a lot of room for a battery so we are having some made to fit the open area where the battery sits now. We should have them in a few weeks. If anyone is interested please let us know ([email protected] ) so we can buy enough for the demand.
One small detail about the handle is that it is pretty much useless. Does anyone actually use it to pick up their car? One thing that one of our drivers noticed is that if you trim off the handle part (leaving the center section where the fuel hose goes through) the motor runs at least 10 degrees cooler. The handle seems to break up the airflow under the body shell. A small detail but really helps on hot days.
Wolf Hobbies Your Source for Everything Team Magic Kfactory and H.A.R.D. in the USA www.wolfhobbies.com [email protected]
Wolf Hobbies is offline   Reply With Quote
Old 04-13-2009, 11:04 PM   #389
Chiefy 707's Avatar
Wow, this thread has died!
I used to think XRay was retarded for selling front uprights in only ones (either one left or one right) rather than the usual pair like everyoine else does. Then last raceday when I needed a spare, I realized I have a bunch of lefts but no rights so I had to run a left upside down to finish the main.
The car turned alot faster in one direction than it did the other and no longer felt easy to drive BTW.
Thought I'd just share that since this thread has died. Where did all the +Evo love go?
PS yes I am aware that running my upright upside down effectively changed my steering and suspension geometries but you gotta do what you gotta do to race right?
Old 04-14-2009, 01:10 AM   #390
freestyles's Avatar
Trader Rating: 14 (100%+)
Do you mean your front knuckles where your axle runs through the two bearings? And did you use an X-ray knuckle or were you just using that as an example?
Hey keavze what is that alloy piece where your handle usually goes? Did you make it yourself or did you buy it? Wolf hobbies posted earlier that if you cut down the handle it drops motor temps by 10 degrees, is this why you did it?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
What to do with my G4? .:Andy:. Nitro On-Road 31 02-02-2009 02:26 AM
Xray NT1 vs Team Magic G4S badKarma Nitro On-Road 35 10-13-2007 02:26 AM
RD Logics Mongoose G4 Team Magic Evo Nitro Touring Car lidebt2 Nitro On-Road 20 08-11-2007 06:38 PM
Team Magic G4 Evo, must sell Raul Garcia R/C Items: For Sale/Trade 32 10-16-2004 04:24 PM
