Old 03-03-2009, 08:11 PM   #301
D Man's Avatar
i never had any issues using tz, nova mega, 3sct, nova LL3
oh you guys are talking about just the G4+evo, never mind
chiefy any issue with the brake on your evo with the capricorn?
Team VRC
D Man is offline   Reply With Quote
Old 03-03-2009, 08:32 PM   #302
Chiefy 707's Avatar
Originally Posted by keavze View Post
by the way, how's the stock setup for the +evo given in the manual?
any 'better' suggestions? especially about the roll-centers...
As far as the kit suggested settings go I find them to be a good starting point. Here at my local track (which is small, tight, and technical) I find it to be a bit on the understeering side. My lazy ass has been meaning to install my gear diff but like I said, my ass is lazy.
At Speedworld in Roseville(which is large and more open yet still technical, I find the kit settings to almost be spot on. I love driving up there with my +Evo and find I'm a faster driver. Just too bad my consistency isn't there.
I've scoured the internet for setups but it's one thing to get the info and another thing to actually apply it What can I say? My ass is lazy!
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 03-04-2009, 12:04 AM   #303
Sp Racer's Avatar
Originally Posted by Bundy_Bear View Post
Keavze:
Thanks for that information, that means that getting K1443 would be a waste of $10usd. My best solution would be to do as Patto said and machine the original disc down on the bench grider.
TM why have you addressed this issue seeing this would be about the 5th generation of this car!!!!
Kyosho RRR Evo disc works well...
Sp Racer is offline   Reply With Quote
Old 03-04-2009, 12:08 AM   #304
Sp Racer's Avatar
Originally Posted by qcrc View Post
Team Magic G4 Suspension Springs Data
COLOR WIRE LBS/IN gf/mm
gray 1.90 52.00 929
orange 1.80 41.50 742
blue 1.70 31.00 554
aqua 1.60 26.00 465
silver 1.60 26.00 465
purple 1.50 20.00 357
pink 1.40 17.00 304
fuccia 1.30 13.50 241
green 1.20 11.00 197
The silver springs you have listed here - surely not the kit ones ?
Would you happen to have a Mugen & Kyosho table by any chance ??
Old 03-04-2009, 01:27 AM   #305
freestyles's Avatar
Trader Rating: 14 (100%+)
What about the black springs that come stock with the G4s? They are actually longer than the springs in the TM kit and the ones in the kit are longer again than the silver springs
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 03-04-2009, 02:37 AM   #306
Bundy_Bear's Avatar
when i was using k1443 with OS and picco engines, there're no issues of disc touching the engines...
maybe someone can share what engines will not have clearance for the stock RS brake disc?
I know my HoBao Hyper 12 didn't fit in the G4JS without the disc rubbing on the crank case and engine was on angle to try and get a good mesh. This was with the one bit engine mount.
Also, i would have to check with Patto, but i know he used smaller brake disc with his Picco engines when he ran the G4RS...
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 03-04-2009, 02:39 AM   #307
Bundy_Bear's Avatar
Luis:
Is it any smaller in diameter? Seems to be a few Kyosho parts you like to use on your TM :P
MissMooRC Racing
Old 03-04-2009, 05:25 AM   #308
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the K1443 is the smaller diameter brake disc used for the 2 pin brake pulley of the plastic ED trans. it is the same size as the G4 + disc. so there will never be rubbing issues. the stock disc on the G4JS is the same as the original Mongoose or G4S disc. it is larger in diameter, and has issues with most engines touching the crankcase. they might have fixed the issue with the newer kits with the use of the smaller disc, but anyone running the G4S disc must make it smaller in diameter, i mean less than 1mm from center is more than enough clearance. also what i did , was to use the plastic pulley std shaft, and grind a flat on it and use the G4+ alloy brake pulley and the disc, use loctite on the grub screw, and it works a treat. this i did because i had a few alloy pullies to use up, so i got the use of it and the smaller disc.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-04-2009, 07:55 AM   #309
D Man's Avatar
i bought 2 G4S's and they both came stock with silver springs front and rear ..shorter than mugen rear and longer than mugen front springs never seen a black one on stock G4S's
Team VRC
Old 03-04-2009, 08:27 AM   #310
keavze's Avatar
k1443 is actually bigger than the alum ed disc. i've got 3 of the different disc; k1443, alum ed disc and rs disc. i was using k1443 for my g4s last time and it is 1mm larger in dia than the alum ed disc.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-04-2009, 02:47 PM   #311
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Post set up
any one got a site with any g4 set ups from team drivers and such ???current please not from 3 to 5 years ago thanks .
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 03-04-2009, 03:17 PM   #312
Pattojnr's Avatar
do you have a G4S disc ? this is the one that is giving Bundy the problems. the K1443 is probably the disc to use as it is still smaller than the G4S disc. i had this problem early on with the mongoose and the G4S, it did hit the engines, so can you help undies and give some measurements of the discs, so he knows when to stop grinding the disc down on the JS. Cheers.
ps : i dont have any TM stuff left so i cant measure a thing for him.
Serpent - Walter RC
Old 03-04-2009, 04:04 PM   #313
D Man's Avatar
" http://www.teammagic.com.tw/en/downf...=downlist&id=2 "
but if you're reffering to the old g4 or s you won't get one from any team driver
Team VRC
Old 03-04-2009, 06:42 PM   #314
Chiefy 707's Avatar
Nope no problems here. But how different is K1443 from 502201?
Old 03-04-2009, 11:27 PM   #315
freestyles's Avatar
Their silver springs are pretty much standard i think on all the kits untill you hop up to the LX shocks or buy the spring kit. When i bought the shocks i'm using on my + they came with blue springs i think around 1.8mm'ish, they are TM shocks but i can't remember the part number. They look and build very similar to the LX ones but they have an all alloy shock cap instead of the plastic/alloy ones on the LX's. When i bought the G4s off my mate (which he said was totally box stock) it came with these black springs, they are 1.4mm and 26.5mm long. They are longer than the 1.4mm ones from the TM spring kit though so i don't like to use them. I don't know what's going on there
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
What to do with my G4? .:Andy:. Nitro On-Road 31 02-02-2009 02:26 AM
Xray NT1 vs Team Magic G4S badKarma Nitro On-Road 35 10-13-2007 02:26 AM
RD Logics Mongoose G4 Team Magic Evo Nitro Touring Car lidebt2 Nitro On-Road 20 08-11-2007 06:38 PM
Team Magic G4 Evo, must sell Raul Garcia R/C Items: For Sale/Trade 32 10-16-2004 04:24 PM
