Old 12-30-2008, 11:44 PM   #136
D Man's Avatar
now, now chiefy lets not get carried away, i'm simply saying we both know you had enough time to set up your car with the basics, cause we all know that is in the top most important thing that makes the car handles good.. even if you are just breaking it in especially in a race ,we all know we get carried away and just want to push it.. well what's the most important thing is you had fun, could of made it more fun if you finished ,lol ,i'm dropping it now, lol... it's all luv joe
Team VRC
D Man is offline   Reply With Quote
Old 01-03-2009, 11:33 PM   #137
Chiefy 707's Avatar
I'll say this much about the +Evo... that was the easiest, and most fastest hingepin and control arm swap I ever had to do! Front and rear.
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 01-04-2009, 01:40 AM   #138
freestyles's Avatar
Trader Rating: 14 (100%+)
I haven't got the evo but can you elaborate on why it's quicker. Has it got something different to the original plus? Even still i reckon it's pretty quick to change a pin or suspension arm on the older +
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 01-05-2009, 05:33 PM   #139
Chiefy 707's Avatar
Well comparing it to my previous car, this car is a joy to work on. Three screws and you have access to both rear hingepins. Three screws again for each front upper pin. Way less than 5 minutes swapping between the front spool and diff. Pretty much the same for the rear.
Old 01-05-2009, 06:54 PM   #140
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Smile rd logic mongoose g4
hey guys and gals ... i just about finished putting toghether a mongoose from rd logics i am breaking in a motor and need some good parking lot set ups oil and springs suggestions for the shocks ,any one have a general idea of the spring rate of the kit standard silver springs ,i have checked out wolf's hobbies set ups , but those were for smooth prepared super tracks for nats races thanks and remember i love the smell of nitro in the morning
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 01-05-2009, 07:42 PM   #141
revo523's Avatar
A good starting point is the setup in the manual check the last pages.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 01-05-2009, 09:11 PM   #142
D Man's Avatar
factory set up is a good start but i would replace those daym spings to 1.7 in the front and 1.5 in the rear but if you're just gonna run it on parking lots it don't matter what set up you got it won't handle cause it's too dusty
Team VRC
Old 01-05-2009, 11:22 PM   #143
Cool track surface
well they set up the track in a hobbytown parking lot and they do spray the track with a traction treatment ie sugar water but was more looking for a spring and oil set up to start with .thanks
Old 01-06-2009, 12:31 AM   #144
D Man's Avatar
i usually run the 1.7 front 1.5 rear combo on smooth track... on that type of track i start with 1.8 front and 1.6 rear with team magic's springs i don't actually know it by colors, but it should say it by the thickness of the springs also.. 600 oil mugen and stock pistons good luck
Team VRC
Old 01-06-2009, 09:58 AM   #145
afm
afm's Avatar
Originally Posted by D Man View Post
.......with team magic's springs i don't actually know it by colors, but it should say it by the thickness of the springs....
tm gray 1.9mm 52.0 lb/in
tm orange 1.8mm 41.5 lb/in
tm blue 1.7mm 31.0 lb/in
tm aqua 1.6mm 26.0 lb/in
tm silver kit stock 26.0 lb/in
tm purple 1.5mm 20.0 lb/in
tm pink 1.4mm 17.0 lb/in
tm fuccia 1.3mm 13.5 lb/in
tm green 1.2mm 11.0 lb/in
AFM
afm is offline   Reply With Quote
Old 01-07-2009, 03:32 AM   #146
keavze's Avatar
Default WC chassis
is the WC chassis 3 or 4mm?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 01-07-2009, 06:51 AM   #147
Nitro-Racer*'s Avatar
the wc chassi is 3mm
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 01-08-2009, 01:13 AM   #148
freestyles's Avatar
Don't we all If your going to be doing a lot of parking lot bashing they usually aren't the smoothest of surfaces. So i would suggest to drill your shock pistons out to 2 holes at 1.2-1.3mm each. This helps with the sudden impact that these types of surfaces throw at you. The bigger the hole the easier it is for the oil to go through so when you go over a little imperfection at 80+km/h the shock would react very quickly so if the shock can compress easier it will soak up the bumps better, i hope i didn't confuse you.
I would then use 50-60wt oil in them after drilling the holes out with the blue 1.7mm spring up front and the purple 1.5mm spring in the back but lately i have been running 1-2mm spring sizes less all round to try and compensate for little to no chassis flex
hope that helped
Old 01-11-2009, 07:44 AM   #149
87stanggt's Avatar
New to the TM world, is everything included in the evo upgrade kit to make the g4s into the +evo, or are there additional parts that need to be bought? Trying to save a buck!!
>GQ Racing Products
>Blue Diamond
>Team Deceptaconz!
87stanggt is offline   Reply With Quote
Old 01-11-2009, 08:10 AM   #150
helivaguy's Avatar
Trader Rating: 42 (100%+)
Default rx battery
i have the older team magic g4 evo,(using the 800mah pack)does anyone know who on-line sells the AAA receiver battery pack?
or would i be better off making my own pack?
helivaguy is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
What to do with my G4? .:Andy:. Nitro On-Road 31 02-02-2009 02:26 AM
Xray NT1 vs Team Magic G4S badKarma Nitro On-Road 35 10-13-2007 02:26 AM
RD Logics Mongoose G4 Team Magic Evo Nitro Touring Car lidebt2 Nitro On-Road 20 08-11-2007 06:38 PM
Team Magic G4 Evo, must sell Raul Garcia R/C Items: For Sale/Trade 32 10-16-2004 04:24 PM
