Old 10-26-2008, 03:00 PM   #1
modhobby's Avatar
Trader Rating: 25 (100%+)
Default Kyosho Audi/Corvette IGT2 (GXR28SG) motor
So I have I had this Audi car for over 4 weeks. I am having a heck of time getting it to run well. I cannot get it to run under 320 degrees without sacrificing the power, even at 320 the power band is really flat between the mid-top end of the range. I have tried 30% Byrons originally when I got it. Parking lot running. Moved to 20%/12 Byrons for the track, just seemed alright, tried Nitrotane 20% today, then back to Byrons 20%, where I will stay. I tried putting an extra shim on the head. I even tried a another carb from the same stock motor from another racer. Still, just seems flat. It feels like by the time I get to the braking part of the long straight the motor is just starting to come in. Could it be the gearing is not proper for this motor?
BTW, the engine idles fine too.
* FYI: body has 3 inch circle in front, cut out back window, and cut out side windows. So, I mean there is airflow. I am at a loss here.
REDS Racing USA
modhobby is offline   Reply With Quote
Old 10-26-2008, 05:01 PM   #2
hobbipro's Avatar
Trader Rating: 21 (100%+)
I'm picking up one of these http://cgi.ebay.com/Kyosho-GXR28-Nov...713.m153.l1262 Mine engine is the regular GXR28, and it too runs a little hot, hopefully this will help to bring the temps down. I'm running 20% odonnell.
hobbipro is offline   Reply With Quote
Old 10-26-2008, 10:50 PM   #3
guambomb's Avatar
use 16 % you should average about 190 in temps and it will haul a$$
guambomb is offline   Reply With Quote
Old 10-27-2008, 01:46 AM   #4
MikaR's Avatar
The gearing of GT2 is great and suits this engine fine.
It sounds you're running too lean in the bottom and/or top. 320F is 160C which is way too much. Try to lower the temps by 50-60C by richening out. This means 230F or less. Increase the idle if it stalls (it likely will when richening out from those temps).
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
