Old 10-25-2008, 06:01 AM   #1
musti72's Avatar
Default why smaller tires?
hi everyone, i see that every serious racers cut their tires as small as possible. so whats the advantage of running smaller tires? if you say more flex, why dont u harden the springs for example? if its about the rollout, it can be easily adjusted by the spur pinion combinations. so why cut to 60mm instead of out of box 65mm? if you use smaller tires for the solution to the traction roll, is it better to use bigger tires for low traction tracks? the tracks i run on have low to mid traction, and i have never experienced a traction roll. in this case, can i run 65mm tires? thanks for the replies
musti72 is offline   Reply With Quote
Old 10-25-2008, 07:06 AM   #2
lil-bump's Avatar
Trader Rating: 83 (100%+)
Smaller tires have a faster corner speed
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-25-2008, 08:06 AM   #3
wizby's Avatar
I think it has something to do with the angle of the lower suspension arms. When you lower the chassis down with 65mm tires the lower arms are not at a correct angle for best handleing. I could be wrong but my touring car handles better with 59mm tires on it. Besides that there is something about sidewall flex of the tire.
wizby is offline   Reply With Quote
Old 10-25-2008, 08:28 AM   #4
KyoshokiddT.D's Avatar
The smaller the tire the less rotating weight Which means more punch of the line. Also the tire wont roll over. The bigger the tire the more the tire rolls and will push.
KyoshokiddT.D is offline   Reply With Quote
Old 10-25-2008, 09:47 AM   #5
ziggy12345's Avatar
Hi
Yes it takes much more power to rotate something heavy than it does to more it in a straight line. Lighter wheels gives better acceleration
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-25-2008, 02:31 PM   #6
Hey Ziggy have you done anymore work to your Big Block V-1RRR yet??
nitrohead5300 is offline   Reply With Quote
Old 10-26-2008, 01:16 AM   #7
freestyles's Avatar
Trader Rating: 14 (100%+)
As i understand it's called "roll out". You can alter the ratio by making your front/rear tyres at different sizes. Usually the front tyres will be smaller than the rear tyres, this is called the "split". Go to the serpent website and they heve a drive calculator and you can see what happens when you alter wheel diameters.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 10-26-2008, 09:03 AM   #8
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Less prone to chunking , traction roll , lower unsprung weight , lower weight , more efficient suspension.
But depending on my cash flow I adjust accordingly.
Artificial-I is offline   Reply With Quote
Old 10-26-2008, 09:18 PM   #9
Split Pin's Avatar
I like the last bit of your quote so true that is basically what it boils down too I think that quote is great
Split Pin is offline   Reply With Quote
Old 10-27-2008, 11:00 AM   #10
Perez's Avatar
I try to run the biggest size tire that i can, mainly for cost purposes, especially at club races. At bigger races ill cut those suckers way down because it does make a difference.
Perez is offline   Reply With Quote
Old 10-27-2008, 09:06 PM   #11
RevMaxx's Avatar
Send a message via MSN to RevMaxx
for club races, what tire diameters do you true your front/rear?
RevMaxx is offline   Reply With Quote
Old 10-28-2008, 01:54 AM   #12
redsand's Avatar
Send a message via Yahoo to redsand
The smaller the tire the faster it wears.
redsand is offline   Reply With Quote
Old 10-28-2008, 03:31 AM   #13
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi, only smaller tyre can make your lap time faster.....with the correct split size , u will notice the difference ...
good luck!
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-28-2008, 03:52 AM   #14
Sp Racer's Avatar
Actually, sometimes it works the exact opposite
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 10-28-2008, 06:28 AM   #15
lil-bump's Avatar
It depends on tire wear. If the club race is on a parking lot surface with high wear then I will start with a little taller tire. As you practice and run your quilifiers you will get a feel for what the tire wear is in 5 min. From there you can judge how much tire wear will be needed for the entire main. The key is to have enough tire for the 5 minute qualifier and for the main or if a tire change is needed for the main.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 07:04 PM
Rain City rcracerric Northwest Racers 6484 04-30-2011 01:01 PM
RCGT USA charlie_b Racing Forum 894 09-23-2010 04:43 PM
The Speedtech RCGT Showdown Hebiki Racing Forum 1308 01-21-2010 03:12 PM
rubber touring tires??? JuNK??? burbs Electric On-Road 30 06-15-2006 04:17 PM
T.M. Tires User Thread darnold Electric On-Road 159 03-11-2005 02:02 PM
