Filter Oil
Old 09-24-2003, 07:03 PM
Filter Oil
Is there a cheaper alternative to hobby shop (expensive) filter oil? I have heard of Marvels Mystery Oil, but that is not available in Australia.
Sami
ttektek is offline
Old 09-24-2003, 07:10 PM
AMGRacer's Avatar
Go to a motorbike shop the has dirt bikes. Just get some filter oil for the foam sock type filters. I got a litre bottle for $13.
AMGRacer is offline
I use Marvel Mystery oil, but I have heard you can also use a good transmission fluid.
nitro dipstick is offline
Old 09-24-2003, 07:30 PM
Manticore's Avatar
a lot of fuild do the job including nitro fuel. but make sure to remove excessive fuild from running around the foam filter with tissue paper. excessive fluid will carry dirts into the engine.
Manticore is offline
Old 09-24-2003, 08:32 PM
In a pinch, I just use after-run oil. Works just fine.
If not, I usually have some oil on hand, because it's only like 3 bucks here.
RLich8 is offline
Old 09-24-2003, 09:03 PM
FAST1's Avatar
After-run oil or your fuel is all you need.
FAST1 is offline
Old 09-24-2003, 09:11 PM
AMGRacer's Avatar
I would invest in some more tacky oil if you can. The fuel and afterrun oil does work no doubt, but the stuff for dirtbikes is ULTRA tacky and ensures maximum protection.
AMGRacer is offline
Old 09-25-2003, 03:17 AM
EVOLUTION's Avatar
Default Re: Filter Oil
Sami
Get some "castrol dirtbike foam air filter oil" from your local auto parts store.I've had mine for years and it's not even half empty.It costs around $15 and is really tacky and not very restrictive,at least that's what they say on the bottle !!!
EVOLUTION is offline
Old 09-29-2003, 04:39 AM
Lonestar's Avatar
castor oil or after run oil are usually interchangeable...
Paul
Lonestar is offline
Old 09-29-2003, 05:20 AM
stefan's Avatar
K&N filter oil.
Comes in a box with a can of oil spray and a bottle of cleaner.
$10 @ Pep Boys, killler stuff.
stefan is offline
Old 10-04-2003, 05:10 PM
i can tell you a very cheap air filter oil and one quart will last forever..i use hypoid oil..works awesome and is very sticky..just like filter oil..i can buy a quart at my local automotive for 2 bucks..in other words im talking about gear oil for rear ends and stuff on trucks..
2mcgrath is offline
