Old 01-16-2002, 03:45 AM   #1
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Thumbs up Collari new engine
Check this out......
Looks like another 5 Port Turbo.....
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 01-16-2002, 03:53 AM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
The same thing from Yokomo last August
Manticore is offline   Reply With Quote
Old 01-16-2002, 04:02 AM   #3
hurhur's Avatar
its a PICCO!!
will go for RB 5 ports anytime....
hurhur is offline   Reply With Quote
Old 01-16-2002, 04:03 AM   #4
Michael_T's Avatar
Im only seeing Picco engines which are already on the market on that page Moon
Old 01-16-2002, 04:03 AM   #5
Michael_T's Avatar
Originally posted by hurhur
its a PICCO!!
Whats a Picco???? Im lost here
Old 01-16-2002, 04:14 AM   #6
Manticore's Avatar
Novarossi: this engine doesnt have your blood inside. Its a picco. Collari only mod picco engine now !
Old 01-16-2002, 04:18 AM   #7
Michael_T's Avatar
Yeah Yeah I know Picco manfacturer all of Collari's engines, but how is that engine in your link (Yokomo page) the same as the Collari above
Old 01-16-2002, 04:20 AM   #8
Manticore's Avatar
You need to ask your competitor or Mr. Collari ! hahaha
Old 01-16-2002, 04:20 AM   #9
Manticore's Avatar
Yokomo released the same engine last August !!
Old 01-16-2002, 05:21 AM   #10
Mauler's Avatar
Send a message via ICQ to Mauler
So u mean Collari improved the previous 5 port, or is it that our dear Mr Novarossi's behind time?
Mauler is offline   Reply With Quote
Old 01-16-2002, 11:23 AM   #11
Motorman's Avatar
Yes it is a picco RR. Ok all you Mr Wizards just how is it a five port? (yeas it has five holes but is it really a five port) I only see three in the liner that allows fuel into the cylinder. Those extra 2 on the bottom go nowhere as they are always completely covered by the piston during its entire stroke. Now if there were holes in the piston then they would be meaningfull. If I drilled 27 holes around the bottom of a liner would you call it a 27 port? I don't think so. If it truly had 2 holes in the piston to correspond to those it would be a 7 port and it would be a true statement. And that is exactly why those are there. (Its called a, well you know, for one of those guys that gets cars and engines for free). Be carefull of hype on engines. More ports isn't always better, how they are arranged and what they do is more important. Those run pretty good I hear though. They finally fixed the rod (thank god, in the picco too) and reworked the timing some. The engine is truly a three port still and would be roar legal if the crank had a legal turbo cut in it. The RR is Illegal I know but I havent seen the non turbo plug collari inside yet. I should have that answer next week sometime. The collari and RR non turbo are Ifmar legal though as Ifmar does not have a stupid crank rule like we have.
Time will tell how those stack up. still have a crappy carb on them though, nova carbs and os carbs have it all over them. I do like the three oil catcher holes on the exhaust side to lube the hot side of the piston.(helps prevent siezure) I have used that on a few Eagle engines recently. A few Nova 21's have that to.
ahhhh roar illegal rr crank, the turbo cut is legal as long as it does not enter the tunnel. look like it do in this case. novas are cut on the counterweight not into the tunnel
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-16-2002, 06:04 PM   #12
Ohhhhhhhh, thats what those 3 holes are for, hmmm. Cool. Thanks MM. I remember seeing the pic of the .12 RR. Who posted that pic, back in late summer?
Foger Rox is offline   Reply With Quote
Old 01-17-2002, 12:26 AM   #13
Jonathan's Avatar
Motorman
Let me get this straight. Are you saying the 2 extra ports are totally useless??? And if so, where would the holes have to be in the piston while at tdc?? and why? BTW... I've heard that OFNA has the rights to a 7 port 12...(now I know that it will most likely have the two ports in the piston that you've spoke of) ...comments?? While we are on the subject, I never could understand why you skirt the piston on the RTO. Dying to know. Please enlighten me....
Jonathan is offline   Reply With Quote
Old 01-17-2002, 12:55 AM   #14
Motorman's Avatar
yes that is exactly what I am saying. at no time are they ever contributors to fuel mixture flow in that engine in its current configuration.
The hole location in the piston needs to correspond with the hole. It needs to open just before the transfer ports open as the piston travels downward. It needs to be fully open as the piston reaches bottom dead center of the crank rotation so the holes are going to be just about the same size as those lower ports. The timing of the holes is critical. what this does is scavenge the trapped fuel air mixture under the piston making the engine more effecient. Now I really let a cat out of the bag!!!
Why skirt. If you take the cover off the back of your engine and watch the piston as you roll it down to Bottom dead center you will see that the crankshaft counterweight and the skirt of the piston cuts off the boost port becaust the piston gets so close to the counterweight. This is why I use a double skirt on my pistons as it allows the transfer path to stay open. It keeps the port flow from going zero at BDC which is bad for combustion chamber and cylinder fill turbulence. Turbulence makes power done the proper way. RTU's share the same piston and liner design as the RTO. Its just that the RTO has more exhaust timing.
Old 01-17-2002, 01:04 AM   #15
Jonathan's Avatar
AMEN!!
!!!!F/S Collari B7 Buggy Engine!!!!! Steelwill R/C Items: For Sale/Trade 74 08-03-2008 08:50 PM
WTA: M.Collari .21 engine guess Nitro Off-Road 1 11-11-2007 08:53 AM
Collari B7 engine Davidka R/C Items: For Sale/Trade 2 04-30-2006 10:32 AM
HELP with L Collari engine Dpepin Onroad Nitro Engine Zone 2 08-21-2005 10:11 PM
collari engine civicsi Nitro On-Road 14 03-17-2004 08:38 AM
