Old 10-19-2008, 12:04 PM   #1
tanisg's Avatar
Send a message via MSN to tanisg
Default sirio evo-4sti
Good Evening
Recently i bought a new Sirio EVO 4 sti engine. I br0ke-in normaly and finally tunned from a person that has more experience by me. The engine raised 105 degrees C and we put him to race. The engine run out of fuel in 3:40. I don't what is the problem and is not wasting from nowhere and the pipe is that proposed from Sirio. Do you anyone knw something..? Or he bellieved that is..?
www.rcmaniacs.gr
tanisg is offline   Reply With Quote
Old 10-19-2008, 02:26 PM   #2
GREGORY!'s Avatar
just lean it since 115-120 celsious.you must be a bit rich.
GREGORY! is offline   Reply With Quote
Old 10-20-2008, 11:14 AM   #3
GEO
GEO's Avatar
Send a message via MSN to GEO
I don't think that with 15 degrees C will gain 1:50 minutes during the game and after all why to do this..? I was tanisg pitman in FRT with someone else and it was the first time that i see this despite my experience..Do someone know what could be...?
Xray NT1 | RB modified NDS TECH | Hot Race | ORCAN | FUTABA
FANATIX MODELS - TEAM XRAY GREECE - RB PRODUCTS
GEO is offline   Reply With Quote
Old 10-20-2008, 02:37 PM   #4
Speyederjedi's Avatar
If your low end needle is still close to the factory setting it is possible the engine could use up all the fuel in 3:40.
While the engine is running pinch the fuel line that goes to the carb and if the engine continues to run for more than 6 or 7 seconds it's to rich on the bottom. When you pinch the fuel line the engine should start cutting out in 3 to 4 seconds, if the motor continues to run at the same idle during that time the low end is too rich.
The Siro Evo 4 STI is a great motor and can still be surprisingly fast even when running rich. It just sounds like the motor is to rich at your current settings.
Also, don't rely on tempurature only. The motors being put out nowadays can run at higher temps and still perform really well. As long as there is a trail of smoke coming out of the exhaust from the low to high RPM range you're okay. I've had motors that run their best at 260-280F and they're still fine.
Hope this helps.
Speyederjedi is offline   Reply With Quote
Old 10-20-2008, 08:31 PM   #5
Chemical X's Avatar
Trader Rating: 16 (100%+)
Make sure the seal between the carburetor and the engine block is not leaking. I have this same engine and couldn't get the engine to run correctly until I fixed a carburetor leak with orange RTV silicon.
Chemical X is offline   Reply With Quote
Old 10-20-2008, 08:35 PM   #6
sandfan85's Avatar
Like you even know anything about Nitro motors!!!!! Electric BOY
sandfan85 is offline   Reply With Quote
Old 10-20-2008, 09:53 PM   #7
Team Kamikaze's Avatar
Hey Tom,
Are you going to let Steve B. talk $#!t against you?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-20-2008, 11:15 PM   #8
Chemical X's Avatar
Originally Posted by Team Kamikaze View Post
Hey Tom,
No way!!!
What are talking about? I kicked your a$$ in gas sedan at the Region 11 regional race last month.
Oh wait... Damn it I forgot... You won and I got second.
Old 10-21-2008, 04:23 AM   #9
rcabj's Avatar
yeah i think u r still on the rich side
anyway i was told by more experience racer's here that the evo sti does not require heavy brekin in process like most engines. some only after 2-3 tanks and then they start to fine tuning.
i also was told some latest engine products that no longer requires breakin. unbelievable, believe it.
i also own an evo 4 sti. just being safe what i did for break in was 2 tanks on the box and 3 tanks on the track for break in. after that i tuned it to race conditions. during the process i gradually closed the main needle bit by bit. now it already went through 3 races and still going strong
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-21-2008, 06:34 AM   #10
GREGORY!'s Avatar
τωρα τι λες?εχω δικιο?
something else,what exhaust do you use?
Old 10-21-2008, 07:17 AM   #11
GEO
GEO's Avatar
Σε τι να έχεις δίκιο φίλε..? Εχουμε αλλα 3 ατομα το ίδιο μοτερ στην ομάδα και πρώτη φορά το συναντάμε αυτό..Kαι πυροβολάνε σε ρυθμους αγώνα με το πολύ 105 βαθμους..το χειμώνα..και σβήνουν πάνω κάτω στα 5 λεπτά.. Σίγουρα όλα τα μοτερ δεν ειναι ίδια αλλά με μία φόρα το δικό μου EVO 4 που βάρεσε 130βαθμούς χαλασε το μεσα ρουλεμαν(ετοιμο να σπάσει και απο τότε εβαλα κεραμικά)
Tanisg use: EFRA 2611 exhaust
Old 10-21-2008, 08:28 AM   #12
GREGORY!'s Avatar
he has the same gearing with you?the same clutch settings?the same fuel and it makes 3.5 minutes?just try a more lean setting and see what you will get.how much liters the engine has?
and i dont think that now here we have winter.
Old 10-21-2008, 03:10 PM   #13
GEO
GEO's Avatar
Yes, he has the same car and the same gearing and the same clutch settings...Only the fuel is not the same...The engine is new and has only 1liter..
I don't say for now...but for the winter genelar..
Old 10-24-2008, 11:46 AM   #14
Corse-R's Avatar
Bingo! that's the main problem. Only has 1 litre thru the sleeve. Like many others said, should be filthy rich and still needs time to start showing real muscle. As a general rule I don't race an engine if at least don't have 5 litres thru it (and of course, after a conrod change - Sirio conrods get a really heavy pounding on the first litres of piston life).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-24-2008, 12:37 PM   #15
GEO
GEO's Avatar
Τhank you for your help...
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
DO NOT BUY SIRIO EVO III xxx123 Nitro On-Road 39 06-23-2009 03:15 PM
New SIRIO S12 TRP EVO 2 afm Nitro On-Road 26 12-24-2007 10:29 PM
OS 12 TZ "Speed Tuned" OR Murnan OS 12 TZ OR Sirio EVO III T3-E??? TNC Nitro On-Road 21 12-01-2006 06:17 AM
