Engine Change
Old 10-19-2008, 01:56 AM
madbeats's Avatar
Default Engine Change
Just wondering do you guys change your engines every season or not ?
Please can you explain why you do so
madbeats is offline
Old 10-19-2008, 04:43 AM
aussies1129's Avatar
Trader Rating: 74 (100%+)
Hi,
it would depend on what engine, I run factory tuned engines where the piston and sleeve are not available as a seperate item so I would change when I feel there is a power loss or any wear on the piston etc, if I were to run a non tuned engine I would just look at changing every year the piston,sleeve,rod and bearings and any orings around the carb and or back plate but the same again only if I notice a reduction in power.
cheers
aussies1129 is offline
Old 10-19-2008, 06:14 AM
madbeats's Avatar
Default More comments
Originally Posted by aussies1129 View Post
Hi,
cheers
So you only change the engine when you can’t get the best performance from it or even after you have done a rebuild.
Please can more of you guy's, make some comment of your experience?
madbeats is offline
Old 10-19-2008, 07:03 AM
jameslow's Avatar
just wounder.... the cost of changing the piston, sleeve, bearing blah blah blah.... wont it be better to get a new engine???
just my 2 cents! hehe! Thanks!
jameslow is offline
Old 10-19-2008, 11:27 AM
freestyles's Avatar
Trader Rating: 14 (100%+)
Motors can run forever but can't run forever and produce 100% power so to stay competitive i would change it after a season. If you can change piston, sleeve, rod etc for a fraction of the cost of the motor then i would do that. If it's to expensive then yeah go a whole new motor.
I haven't changed the motor in one of my cars for at least a year and it's still pretty good. (It all comes down to how well you brake it in i think) But it's not as fast as some of the NEWER motors out there though
freestyles is offline
Old 10-19-2008, 08:56 PM
After on eseason thay just get better for me
quiklyonit is offline
Old 10-20-2008, 12:01 AM
it makes sense why buy a new engine after a year when it still is performing well???
so you think its better to buy a new engine say a nova 353 for approx $499 than replace the piston sleeve etc for under $200?? if you got the $$$ this shouldnt be a problem I guess.
Old 10-20-2008, 05:54 AM
jameslow's Avatar
no la...of course not nova!!!! it is different... haha.... i mean the others... which end up like $100 diff only....
jameslow is offline
Old 10-20-2008, 05:59 AM
if it was a JLR redot then get a new engine dont bother with replacing parts
Old 10-20-2008, 06:10 AM
keavze's Avatar
ya i agree...
if rebuild going to cost you about 50% or more of a new engine price, then don't bother rebuilding.
keavze is offline
Old 10-20-2008, 08:46 AM
Speyederjedi's Avatar
As some have posted, it's a judgement call based on cost to rebuild vs price on a new motor. I personally have had motors which have been great and rather than buy a new one I rebuild or have the sleeve pinched. I have a Ninja .12 that I just had modded and pinched and it's almost as fast as my Evo 4 STI. It's definately faster than when it was brand new so it was worth the cost for me to have it modded and pinched. On the other hand I had a couple of WASP's that were crap and rather that rebuild I chose to go with a different manufacturer altogether. So if the motor in question has worked well for you I would say keep it and rebuild it or have it pinched and modded. You might be surprised.
Speyederjedi is offline
