Old 09-23-2003, 02:34 PM   #1
Default Impulse Pro Street Spec???
WHERE CAN YOU GET THIS KIT? ALSO WHATS THE DIFFERENCE BETWEEN THIS AND THE 705 OTHER THAN THE TIRES AND CLUTCH
I'M DEBATING BETWEEN THE TWO i JUST WANT A RACE READY CAR AND LIKE SERPENT ALOT AND THE IMPULSE WILL PROBABLY BE CHEAPER. ALSO ARE THE NOVAMEGA 3PT TURBOS ILLEGAL IN RACES OR IS IT JUST THE 5PORT? IS THE SX12RE 3PT JUST AS FAST
tHANKS
JON
famous182 is offline   Reply With Quote
Old 09-23-2003, 03:08 PM   #2
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Impulse Pro Street Spec???
tHANKS
JON
You might have it mixed up. Impulse Pro has been out for years. 705 is its revision.
eddiethefish is offline   Reply With Quote
Old 09-23-2003, 03:17 PM   #3
http://64.70.208.72/speedtechrc/161.html
sook is offline   Reply With Quote
Old 09-23-2003, 08:48 PM   #4
Arun's Avatar
You should probably go with the 705. The impulse pro is only about 40 bucks less just about anywhere you look.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 09-24-2003, 01:28 AM   #5
InitialD's Avatar
I don't know if Jon (the original poster) is referring to the supposedly repackaged Impulse Street Spec Carbon version (801015) that does not have the Centax, rubber tires instead of foams, one way front, rear gear diff, without shock towers and includes the carbon graphite upper deck.
I believe it's a Impulse PRO without the shock towers and foam tires and very much cheaper than the 705. Basically aimed at entry level racing car competition.
Old 09-24-2003, 08:38 PM   #6
TurnNBurn's Avatar
Sounds like it D... I believe the actual name is the Impulse Streetspec Pro Racer... It comes with the old Rubber tires/wheel combo that hte original Streetspec came with, and has the Pro's CF radio plate instead of the original plastic one. There's a picture of it in from the Chicago show in this thread.
TurnNBurn is offline   Reply With Quote
1/10 Serpent Impulse - Street spec with Nova Mega motor and tuned exhaust ciccarello_mark Australia For Sale/Trade 3 03-06-2011 08:38 AM
1/10 Serpent Impulse - Street spec with Nova Mega motor and tuned exhaust ciccarello_mark R/C Items: For Sale/Trade 4 04-11-2008 11:10 PM
Serpent Impulse Street Spec Pezz R/C Items: For Sale/Trade 13 04-02-2005 07:56 PM
Serpent Impulse PRO, not Street Spec Solara R/C Items: For Sale/Trade 0 09-16-2002 02:49 PM
Street Spec Cheese R/C Items: Wanted to Buy 0 10-14-2001 09:54 PM
