Old 11-09-2008, 12:21 PM   #76
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by the_geeky View Post
Umm, you report people when they do something wrong. Can you tell me what I did wrong? Its called free speech, you know.
Free speech has nothing to do with common respect in a forum. Furthermore Scott merely posted a link to a product of similiar design im guessing because of the better price and availability on the product. Which im sure quite a few people could say they are glad he found that for them.
Second , im a moderator here and I wont tolerate dissrespect and to be honest anyone who insists on the free speech for a reason of why to be a blatant immature child in a forum / xbox live / bars or anywhere else privately owned wont be tolerated. I have recorded the incident and if you continue this behavior I will remove you from this forum.
Calm down and get back to learning about this great hobby, which a lot of people consider a hobby of a way to enjoy themselves and relax, which is best started by simply reading , once you feel you have respect for another individual you can then post again.
Youve been warned!
Artificial-I is offline   Reply With Quote
Old 11-09-2008, 06:06 PM   #77
Suspended
Artificial-I thank you.This GEEKY has no respect!
kyosho player is offline   Reply With Quote
Old 11-09-2008, 07:42 PM   #78
DogboneS's Avatar
Trader Rating: 20 (100%+)
Roelof, if you add a pressure regulator/blow-by to the mid point you'd have a 2-n-1 device(product)
DogboneS is offline   Reply With Quote
Old 11-09-2008, 09:37 PM   #79
wingracer's Avatar
Trader Rating: 24 (100%+)
I was kind of thinking the same thing. Maybe just drill and tap it for a needle valve.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-10-2008, 12:14 AM   #80
Roelof's Avatar
Send a message via ICQ to Roelof
An old project of a friend of mine (made already 2 years ago)
A device I already worked with 5 years ago:
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-10-2008, 12:21 AM   #81
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
awesome invention . I try to think the same ... but just can't figure out the extra fuel hose ... i want to know more. Cool indeed
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 11-10-2008, 03:04 AM   #82
Roelof's Avatar
That is just a simple nipple placed at the side of an empty fuelfilter.
The fuelhose is just for flowing away dirty oil which are with the exhaust gasses. The pressure in the tank is lowered, it makes the engine less pressure sensitive, will react better on the throttle and gives 15 secs more runtime.
Old 11-10-2008, 03:19 AM   #83
jfc_tech's Avatar
thanks for the explanation. Now I understand why the extra fuel hose there. awesome
Old 11-11-2008, 12:12 AM   #84
ConciliumDesign's Avatar
Default Coolers
Thanks for the inspiration Roelof. I'm going to try fabricating a copper cooler since copper conducts heat better than aluminum. Anything for that extra 30 sec! I'm also going to try cooling my fuel before each heat and pit with chilled fuel as well. Watch out for the guy with the insulated fuel bottle!
RC8, RC8T, SC8, Go Power, DX3R, custom fabrication and design
ConciliumDesign is offline   Reply With Quote
Old 11-11-2008, 05:48 AM   #85
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
This might sound strange, but looking around the house for something to work with, I found a piece of aluminum that has "fins" on it lengthwise and it was hollowed out already....it was from when I put verticle blinds up in the house and had to shorten it. You can buy an 8foot blind for $22 for the top rail an dull the "aluminum dowel" from it and have enough to make about 40 of these coolers.
As for the chiled fuel...I used to run this in my nitro oval car, because we were hardly ever off the throttle...be careful as to not keep the fuel too cold, as this can cause signifigant engine issues. Just keeping it 20 or 30 deg cooler is all that is needed. When you get cooler than that, after refueling, I've seen guys that have fractured pistons and had bearing failures.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 11-11-2008, 11:00 AM   #86
Suspended
Originally Posted by HOVIK View Post
Nice work.
Username "HOVIK" is not in any way affiliated 00VIP001. Its just some idiot trying to make trouble and made a fake account of me. Disregard any posts by "HOVIK", it's not me. 00VIP001 is the real Hovik
It's the same person that made the fake account "the_geeky"
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 11-11-2008, 12:28 PM   #87
Roelof's Avatar
Also something else to try:
Just use a small party baloon. This will act more as the Team Orion Constant Pressure Device. On full throttle the balloon will blow up a tiny bit and letting go the throttle the baloon will empty itself pushing some pressure in the tank. As far I noticed is that it will give a faster picking up engine going out of the corner.
Oh well, it is just to give it a try without spending lots of money to expensive devices.
Old 11-11-2008, 12:46 PM   #88
expat's Avatar
Hi all,
I do like the creativity which is coming up.
Well, I have not tried any cooling regarding, thus I am still critical on the effects it might have or not...
I have found some RAM (DDR) coolers which might be very efficient and easy to be modified to fit our needs. They utilize a copper pipe (available in 5 and 6mm dia) and an aluminium cooler. Thus it should be easy to cut and fit some preasure nipples. Saw it for 20-25$.
Will give it a try once got some spare time.
Cheers
TP
Novarossi exhaust gas cooler 3600-nexus_memory_heatpipe_cooling.jpg   Novarossi exhaust gas cooler 3600-998382_bb_00_fb_eps.jpg
expat is offline   Reply With Quote
Old 11-11-2008, 02:00 PM   #89
Roelof's Avatar
Ah, heatpipes. I have also some interesting ideas with them. As example a small and lightweight cooling head for the motor. I am still hoping to find a broken computersystem at my work with a full size coolinghead with heatpipes.
But I do have acces to some broken laptops from which I can use the processor coolers....
And a 5 volt fan is also simple mounted on.
Old 11-12-2008, 12:18 AM   #90
expat's Avatar
Yeap, good to hear about some fresh thoughts so
Reminds me, that some guys back in the 80's tried to oil cool their engines. Basically, they used a marine cooling head and a cooler like the exhaust gas cooler. Not sure how they ensured a flow so... Wasn't it Sabatini....
Anyway, I have found the Nexus HRX 5500 RAM Cooler (pic posted prior; 3 colors: black/blue/silver) selling for 8USD online and you guys should be able to make 2 units out of one (140mm length). Plus some preasure nipple and time... Should be a reasonable saving compared to the one heading this Thread...
Cheers
TP
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 07:52 PM
FW Summer Sizzler 2005 FWR Northwest Racers 126 08-21-2005 12:39 AM
2003 AARCMCC IC National Titles quozl Australian Racing 123 10-08-2003 04:41 PM
Novarossi based side exhaust engine (HPI, NovaMega, Paris) rod_b R/C Items: Wanted to Buy 1 08-19-2002 01:42 PM
New Novarossi 1/10 Polished Inline Exhaust icon R/C Items: For Sale/Trade 1 05-19-2002 03:57 PM
