Old 09-21-2003, 02:06 PM   #1
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
One-Way Gets Hot?
I've been running my Nitro TC3 with a Yokomo one-way... I've been wondering if anyone else's one-ways get hot after a run? Mine does, my friend doesn't think they should.
Nrctc3 is offline   Reply With Quote
Old 09-21-2003, 03:29 PM   #2
Send a message via ICQ to Cartman
you do lube it?
i would also check itsthe right one and many of the tc3 parts are not metric as the yok is
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 09-21-2003, 07:41 PM   #3
Roger's Avatar
Yokomo did make a oneway for the NTC3. You need to re-lube it.
Just use some associated clear grease.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-22-2003, 05:28 AM   #4
serpant one way lube is the only good stuff to use!
Old 09-22-2003, 07:13 AM   #5
I am not a serpent fan, however, I second that statement !! the serpent one way lube is good stuff !!
coolracing is offline   Reply With Quote
Old 09-22-2003, 07:45 AM   #6
its the only good stuff they make!!!!
Old 09-22-2003, 09:13 AM   #7
Send a message via Yahoo to TambokGT
you can't use any grease other than one-way lube.
TambokGT is offline   Reply With Quote
