Old 10-07-2008, 08:49 PM   #1
Renault_Tech's Avatar
Default Setup question
I have a Kyosho FW06 and recently purchased the Integy setup station. I had a fiddle with it last night and was trying to set the camber to negative 1 degree. I can get this reading but the hub has a huge amount of play in it. Is this normal and if not, what can be done about it?? Im adjusting camber using the allen key holes on the hub. One at the top and one at the bottom. Thanks for the help and can anyone suggest some good baseline settings for me? The suspension geometry is similiar to the V-One RRR.
Matt
Renault_Tech is offline   Reply With Quote
Old 10-07-2008, 08:55 PM   #2
nitrodude's Avatar
You have to tighten the plastic nuts that hold the pivot balls in orther to get rid of the play. Thighten them until theres just a little bit of play, if you get rid of all the play it will bind up the suspension. Then set your camber again.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-07-2008, 09:38 PM   #3
yeah if i tighten them too much it does bind. When i have the camber set the way i do, its too sloppy. i cant get the camber i want without having that loose suspension.
Old 10-07-2008, 10:47 PM   #4
avs
avs's Avatar
it sounds like you might be trying to adjust camber with the wrong adjustment. to adjust camber you want to adjust the position of the pivot ball which is screwed into the arm, usually a 2.5mm hex.
the upright (hub) contains the pivot ball with a 4mm hex adjustment. set the 4mm hex to minimum freeplay without binding. then adjust camber with the 2.5mm.
avs is offline   Reply With Quote
Old 10-08-2008, 04:09 AM   #5
freestyles's Avatar
Trader Rating: 14 (100%+)
The best way to get the least amount of play in your pillow balls is to take the steering knuckles off, tighten the hex set screw all the way up so it binds on the pillow ball, then back it off untill the threads on the pillow ball fall down on their own. This should now give you a nice snug pillow ball with no slop and then you should be able to get whatever camber you need.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 10-08-2008, 05:15 AM   #6
ahhh i see now. that makes sense. Ill give that a try and see how i go. thanks for the help!
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 06:44 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 04:10 AM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Midwest Racers Organization (R/C Club) huskerfreak Nebraska/Iowa Racing 1778 04-23-2015 08:19 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
A question about my slash setup... SirJangly Electric Off-Road 23 07-18-2009 12:45 PM
