Old 09-20-2003, 08:58 PM   #1
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
Default after run oils
i was wondering if i could use 3 in 1 oil for after run oil i have been using wd-40..i have a n4tec with a os 12cvrx and a hpi rs4 3 ss..traxxas says to use wd-40 but hpi says not to and i dont have a local hobby shop nearby.. so it gets old running out of afterrun oil and having to wait on it to get here thanks...
2mcgrath is offline   Reply With Quote
Old 09-20-2003, 10:15 PM   #2
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Re: after run oils
Use 1/1 scale car automatic tranmission oil. I used that for my after run oil
tkhoo is offline   Reply With Quote
Old 09-20-2003, 10:27 PM   #3
so you dont think the 3 in 1 oil would be any good
Old 09-20-2003, 11:21 PM   #4
tkhoo's Avatar
I not sure 3 in1 oil but I used automatic tranmission oil and look good.
Old 09-20-2003, 11:36 PM   #5
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Air tool oil is the best you can get it at any hardware store.
KINGZJ is offline   Reply With Quote
Old 09-20-2003, 11:58 PM   #6
Manticore's Avatar
R/C Tech Charter Subscriber
any metal protection oil base lube with thin wt will do the job.
i use ATF before and now using premium grade engine oil
Manticore is offline   Reply With Quote
Old 09-21-2003, 06:30 AM   #7
Taylor-Racing's Avatar
I was using ATF till a friend at the track suggested to use 2-Stroke oil - like for an outboard motor. It seems so obvious now - and I've run out of ATF.
I'd think any light mineral oil would be fine - even baby oil.
Taylor-Racing is offline   Reply With Quote
Old 09-21-2003, 07:08 AM   #8
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the whole point of using afterrun oil is to eliminate rust...Nitro methane pulls water out of the air(thats why fuel needs to be capped).....And thats why your engine rusts....esp if the fuel company uses bad rust preventatives..
Afterburn Jr from racers choice has ingredients to dissolve the nitro methane in the engine...
http://www2.towerhobbies.com/cgi-bin...?&I=LXEB11&P=7
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-21-2003, 07:10 AM   #9
T-shirt's Avatar
i'm using TORNADO after run oil and i think it's the best
T-shirt is offline   Reply With Quote
Old 09-21-2003, 09:11 AM   #10
thanks for all the help i will try some different things see what works best..i havent had any trouble with wd-40 but i have noticed it makes my engines hard to crank..
Old 09-21-2003, 09:20 AM   #11
also does it hurt your engine if you run it at night or evening and wait till the next day to afterrun it..
Old 09-21-2003, 10:44 AM   #12
corvettecrazy's Avatar
Send a message via AIM to corvettecrazy
no that over night to a few days shouldn't really hurt anything. Hte hobby shop around me actually reccomends only unsing it if you wont use your for a few weeks.
I use marvel mystery oil and put it in after every time I fire it up. seems to work fine and burns right out when it is fired up next time.
corvettecrazy is offline   Reply With Quote
Old 09-21-2003, 04:38 PM   #13
so in a nutshell i guess all the types of oils and stuff mentioned would be suitable to use for afterrun oil
Old 09-21-2003, 10:41 PM   #14
Send a message via AIM to raveupon
i heard that ky jelly was a good lube
raveupon is offline   Reply With Quote
Old 09-21-2003, 11:01 PM   #15
well im afraid that wouldnt work to good
oils Mugen MBX-5 Nitro Off-Road 11 11-04-2007 09:21 PM
omany oils selling out, diff oils, shock oils, after run oils. pcr2nv R/C Items: For Sale/Trade 7 03-01-2006 08:56 PM
oils mikecatts Onroad Nitro Engine Zone 3 10-17-2004 01:13 AM
What Oils? Nrctc3 Electric Off-Road 1 02-19-2004 06:25 PM
Oils ain't Oils! hooked_on Nitro On-Road 11 09-03-2003 03:58 AM
