Old 10-05-2008, 03:15 PM   #1
Default thunder tiger gears
i have just upgraded my ts4n to a 2 speed can any one tell me how to set it up to change in to 2nd coz i think im doing something wrong.
bryn1 is offline   Reply With Quote
Old 10-05-2008, 04:27 PM   #2
freestyles's Avatar
Trader Rating: 14 (100%+)
If you have the two screws wound up to tight the two shoes wont be able to seperate there for no second gear. Loosen them just enough so you can just pull the shoes apart by hand, THIS IS YOUR STARTING POINT. Now drive the car and see when 2nd kicks in. If it kicks in to early tighten the screws one hour so it needs more rpm to open it up, or if it kicks in to late loosen them a little so it needs less rpm to open. It's all about driving it and setting where you want it. I hope this helps you.
The TS4N was my first rc car and it was great to learn on. I have some carbon fibre shock towers if you want them they are yours for $20 (good condition) They are in the sale/trade thread aswell.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 10-06-2008, 12:27 AM   #3
itchy b's Avatar
With the TS4N the 2 speed is a leaver system unlike the newer racers which have a 2 shoe design.
Check to see if you have installed the 2 speed mechanism back to front as from memory, the leaver on your 2 speed needs to be trailing the direction that the 2 speed unit spins.
It is possible that you have installed it around the wrong way & while the car will run fine, it wont shift into second gear.
After checking this and getting it all together again, its just a matter of setting the adjustment screw where you want it to engage in the rev range.
If you have installed it the wrong way around, dont stress as it is very easy to do and has been done before!
Hope this helps you out.
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-06-2008, 01:10 AM   #4
Thumbs up thunder tiger gears
thanks for the help i will try it later and get back to you .
Old 01-19-2009, 01:17 PM   #5
Default 2 speed hep
i have the newer model ts-4n and wondering how to upgrade to a 2 speed does any one know were i can get the bits/kit to do this?
thanks richard
spike_202 is offline   Reply With Quote
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
thunder tiger s3 buggy b-man777 Nitro Off-Road 120 09-21-2011 06:08 AM
Ofna, Schumacher- Nitro stuff burnineyes R/C Items: For Sale/Trade 14 05-06-2009 12:22 PM
