Old 10-11-2008, 04:28 AM   #16
hobbipro's Avatar
Trader Rating: 21 (100%+)
I just picked up the Ferrari GT from Stomer Hobbies, They are selling the Ferrari, and Aston cheaper than anyone else I've seen. I Haven't ran nitro in several years, all my stuff is Brushless EP and mostly lipos, even my planes went the BL route. After I seen one running around on youtube, I was impressed. Mine will be used solely for bashing on the street, my only worry is parts availability. No one sells sells Kyosho in my area, aside from Stormer, who else sells Kyosho parts?
hobbipro is offline   Reply With Quote
Old 10-11-2008, 07:48 PM   #17
When I order Kyosho parts direct from Kyosho, my last two orders have been shipped from Ultimate Hobbies. Next time I need parts, I'll be trying Ultimate directly.
Duster_360 is offline   Reply With Quote
Old 03-23-2010, 12:05 AM   #18
Angry Need Help
Hi to all I am kind of new to R/C cars been playing with them for a little over a year, but I really got the bug real bad I now have 27 of them and for the most part I have been able to repair whatever it is that I break. But I have A real problem with my Inferno GT-2 car when I got it things were good till I tore the center gears out of it I replaced them fine the sales person told me that it was a commen thing to tear them up So anyway since I have done it I cant get A set of gears to last more than about two minute before it take first gear out I know I must be doing something major wrong when I install them I have followed the manual I know all of the parts are in the right spot but still no luck I know what ever I am doing wrong must something that I am not seeing because there really dont seem to be much I can mess up with it any body that could help me on this i sure would be a happy car guy again
navionman is offline   Reply With Quote
Old 03-23-2010, 01:55 AM   #19
MikaR's Avatar
Kyosho has come out / is coming out with a new tranny, get it and you'll be 100% statisfied with the car.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 03-23-2010, 10:45 AM   #20
Zootcapri's Avatar
There are many that would tell you that you need to buy an aftermarket tranny. I have had great success with the stock transmission and gears. You have to adjust the mesh differently than any other mesh you have set. There needs to be NO SLOP between the pinion and the spur. The mesh is set tight... not so that it binds... just real tight. Do not worry about the gears seating... they will seat fine in a lap or two.
I have also found that on the GT2 that the engine mounts will slip a little bit if you have a frontal impact. This slight movement will allow the gear mesh to loosen and there goes the gears. I went to a one piece engine mount and stopped that.
Of course the B versions of the 40-46 is suppose to be out of a new material... I have a set coming and can report on them later... but this discussion has happened several times on the GT thread.
Think tight mesh and your teething woes will lessen.
... more fun than we should be allowed.....
Zootcapri is offline   Reply With Quote
Old 03-29-2010, 12:04 AM   #21
MikaR's Avatar
Here's the new Kyosho GT tranny - good quality and Evolva -like lighweight construction. Fully ballraced.
GT3 will have this out of the box plus a .25 installed.
Old 03-29-2010, 12:34 AM   #22
air8's Avatar
How long is that tranny with both outdrives attached?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-29-2010, 01:02 AM   #23
MikaR's Avatar
It's a drop-in to a GT2. Roughly about the same dimensions as before (i.e. with the previous tranny). Have a GT1 electric Ferrari, so I cannot compare, sorry.
Old 03-29-2010, 09:49 AM   #24
JLock's Avatar
Mika,
I saw on the other forum the two-speed pinion gears you got for your electric conversion. Where did you find/get that from? To run it as an electric and not lose the two-speed capability would be fantastic!!
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 03-29-2010, 10:40 AM   #25
MikaR's Avatar
Correct JLock - I got the shaft from RC Monster. Pinions are from Kyosho Evolva.
Old 03-29-2010, 10:52 AM   #26
JLock's Avatar
Thanks. I have checked out their site before and did not know that they had the shaft to do that.
Texas 5
Old 03-30-2010, 04:11 AM   #27
MikaR's Avatar
Yes. It will look like this:
Old 03-30-2010, 06:43 AM   #28
air8's Avatar
Thanx MikaR for the response.
Here's another questions. Does anyone have a rough measurement of the length of the front and rear center diff mounts? How far from the front mount to the rear mount? I'd like to know from center of front screws to center of rear screws if possible.
Thanx if anyone can measure for me.
--"U Ain't Fast!!"
Chris Pearce
Old 05-05-2010, 10:07 AM   #29
Default INFERNO GT2
HOW CAN I MAKE MY CAR FASTER I ALREADY HAVE A PICCO 28 N A JP4 PIPE WITH THE NEW 2 SPEED?????????
pepsi151 is offline   Reply With Quote
Old 05-05-2010, 10:56 AM   #30
Jspeed's Avatar
With the combo you mentioned above, try taller clutch bell gears (17/21) and a new Warrior body.
Jspeed is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Kuala Terengganu RC Track smilekt Malaysian R/C Racers 29327 03-12-2016 11:01 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
OS Max .30 For Sale...NEW!!! biggin69 R/C Items: For Sale/Trade 6 07-09-2008 02:56 PM
NYSC 1/8 Inferno GT interested in racing kcrunchone Nitro On-Road 23 09-13-2007 03:07 AM
